1LC v1.1 toolboard with Euclid probe.
Need some help please
Mini 5+ with a 1LC toolboard v1.1
Just removed the BLT, wired the Euclid using 2 wires, sig and gnd. to io0 on the 1LC
It is a microswitch.
Dropped the config in and it has thrown errors.18/11/2021, 17:47:27 Error: G31: Invalid Z probe index 18/11/2021, 17:47:26 Error: M558: M558: only Z probe types 8 and 9 are supported on expansion boards 18/11/2021, 17:47:26 Error: Invalid remote handle My Config
; Euclid Probe M574 Z1 S2 M558 K0 P5 C"^20.io0.in" H8 F300 60 T9000 A3 S0.01 G31 K0 P500 X-16.4 Y-29.4 Z2.5 Please can someone shed light on how to use the Euclid with a Toolboard.
@paulhew use p8 rather than p5
@jay_s_uk Thank you.
Will give it a go.
P. -
@jay_s_uk Sorted, thank you. Greatly appreciated.
Now to mount the docking unit to a RailCore!
@paulhew said in 1LC v1.1 toolboard with Euclid probe.:
how does it works ? better than bltouch ?
@joeko My opinion, Yes.
Sinned designed it well.Probing reliability is superb. Servo not required like the BLT. Can be run with just 2 wires, 3 if you want the led.
The BLT that was on my RailCore has been relegated to the bin!P.
what would you say is the big advantage to bltouch ?
i think about to buy one but until now i didnt find feedback about euclid
sometimes my bltouch hang in the heatchamber so i have to open the chamber to fix that -
@joeko Sorry, forgot to add some more information.
look at the video's on here. https://www.euclidprobe.com/ You can see it in action.It comprises of 2 boards. One is docked - this has the microswitch and a pair of magnets. It gets collected when required.
The other would sit where the BLT used to sit. This has a pair of magnets, JST connector and optional Led if you want to bling it.
My last Euclid probe test gave me these results.
1.751, 1.759, 1.756, 1.756, 1.757.Found these from the BLT
1.611,1.6, 1.607, 1.614, 1.595, 1.607,1.604,1.599,1.619,1.602Greater fluctuation, IMO.
Also, the BLT case does not like heat, if you like printing ABS.P.
