M204 with square corner velocity like in Klipper?
I want to use a python script for SuperSlicer for post processing my gcode. Is there an equivalent to the M204 with square corner velocity from Klipper in RRF?
SET_VELOCITY_LIMIT ACCEL=7000 ACCEL_TO_DECEL=7000 SQUARE_CORNER_VELOCITY=8
This has to be transformed into settings for RRF...
Thank you very much,
Pierre -
@medicusdkfz M566?
@medicusdkfz said in M204 with square corner velocity like in Klipper?:
Can you explain to those unfamiliar with Klipper what that command configures?
