    DUET 2 SEND AND RECEIVE DATA
    244
    • alperengokalpundefined
      alperengokalp
      How can we send our G-Codes from another electronic card to the DUET-2 electronic card? Can we use USB or RS-232?
      PCRundefined 1 Reply Last reply Reply Quote 0
      • PCRundefined
        PCR @alperengokalp
        @alperengokalp sure Via USB or via UART. But why not use the DWC?
        alperengokalpundefined 1 Reply Last reply Reply Quote 0
          alperengokalp @PCR
          @pcr What is the DWC? How can I transfer data via USB or UART?
          • PCRundefined
            PCR @alperengokalp
            @alperengokalp You can acces the Duet via a webinterface?
              alperengokalp @PCR
              @pcr I have to use USB or UART. Can you help me to this topic?
              • PCRundefined
                PCR @alperengokalp
                @alperengokalp why that? Just use pronterface via USB or octoprint or repetier host Repetier server
                  alperengokalp @PCR
                  @pcr My client wants to send G-Codes from his card to his DUET card.
                    alperengokalp @alperengokalp
                    @alperengokalp Is the DWC method easier to do this?
                      jay_s_uk @alperengokalp
                      @alperengokalp what are you trying to do?
                      just saw your above message
                      you can send gcodes over serial, usb or http
                        alperengokalp @jay_s_uk
                        @jay_s_uk said in DUET 2 SEND AND RECEIVE DATA:
                        How can I do it ? Do you have an example?
                          @alperengokalp here's HTTP https://github.com/Duet3D/RepRapFirmware/wiki/HTTP-requests
                          USB and Serial are pretty standard
                            @jay_s_uk Does the DUET card save the codes I send from UART or USB to the SD Card or do I have to send the codes piece by piece?
                              @alperengokalp piece by piece
                              alperengokalpundefined 3 Replies Last reply Reply Quote 0
                                piece by piece
                                thank you
                                  @jay_s_uk How many characters can I send at a time?
                                    @jay_s_uk Should I connect the Uart Rx , Uart Tx and GND pins on the DUET board? And How does the DUET card detect which protocol to send data with?
                                      @alperengokalp its just a standard serial connection over UART
