G28 confusion
Hi *,
I'm a bit confused about the G28 command.
I have a coreyx. A mini 5+ on 3.4 beta6.
The problem:
Everything works fine when I home x, y and z with "G28 Y", "G28 X" "G28 Z".So I assume that my home*.g files work fine.
The homeall.g looks like that:G91 ; relative positioning M561 ; Unload the hightmap ;G1 H2 Z5 F6000 ; lift Z relative to current position M98 P"0:/sys/homex.g" M98 P"0:/sys/homey.g" M98 P"0:/sys/homez.g"
The expectation is that the head moves to the center for z-home. That is what it does when I execute it with "G28 Z". But it drives to Y and X max and drives down.
My understanding is that G28 executes homeall.g only.
The funny thing is that z drives down in the center (as expected) when I uncomment the "M98 P"0:/sys/homez.g"" from the homeall.g. My expectation is that Z shall not move at all when I do not source the homez.g from the homeall.g.What is wrong here in my understanding?
Cheers, Chriss
@chriss when there is no home Z move in home all.g rrf will look for homez.g and execute it when you command G28
@dc42 That may explained the behavior that I saw movement of Z when I removed the "M98 P"0:/sys/homez.g"".
So I understood:
G28 will execute "homez.g" if the "homeall.g" execution left z unhomed. Is that what you and @PCR said?Here are some more files:
homez.g; homez.g ; called to home the Z axis ; M98 P"/macros/print_scripts/do_z_probe_probe.g"
M98 P"/macros/print_scripts/z_current_low.g" M98 P"/macros/print_scripts/activate_z_probe.g" M98 P"/macros/print_scripts/speed_probing.g" M98 P"/macros/print_scripts/goto_center.g" G30 Z-99999 G1 Z10 ; lift Z M98 P"/macros/print_scripts/z_current_high.g" M98 P"/macros/print_scripts/speed_printing.g" M98 P"/macros/print_scripts/activate_z_switch.g"
G1 X111 Y120 F6000
You see that there are a lot of macros involved. I'm not sure that it will be clear what I try to do.
In short: I do not understand that the behavior of the z movement is different when I execute homez.g manually or when it is done via the G28.
It looks to me like the z movement from G28 is the movement I do in the bed.g. Does hat file have it's fingers in that G28 cake by any chance?Cheers, Chriss
I found the error in my scripts:
You see that move to X111 Y120 in the goto_center.g? I included a G90 to make sure that it acts as expected. The behavior is fine now, after some fine tuning. I'm more than sorry.....Thanks for the clarification! The execution of homeN.g if the axe N is not homed via the homeall.g. That explains a lot I saw in the past and confused me a couple of times back than.
Cheers,
Chriss -
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
