Remote Handle Errors firmware 3.3
Having a few issues which im not even sure where to start at this point. In a nutshell,
have the duet 3, tool distribution board, 2 tool boards, 3 1xd boards.
Both the duet 3 and 2 tool boards have remote handle errors and im not sure where to start.
The thermistors for the hotends both read 83 degrees or -83 after reboot sometimes reading as high as 2000.
running jss57P2N motors on x and y and a nema 23 via a mks tb6600 on z.
Bl touch v3.1 attached to tool board/extruder 1.
Have tried a new sd card, all firmware for both duet 3 and expansion boards are all 3.3 stable, still getting a "remote handle" error.=== Diagnostics ===
RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (SBC mode)
Board ID: 08DJM-9P63L-DJ3S0-7J9DG-3SD6J-1VJZ9
Used output buffers: 1 of 40 (40 max)
Static ram: 150904
Dynamic ram: 62356 of which 0 recycled
Never used RAM 140932, free system stack 192 words
Tasks: SBC(ready,5.0%,306) HEAT(delaying,0.0%,325) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,774) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,7.2%,93) MAIN(running,87.7%,1131) IDLE(ready,0.0%,29), total 100.0%
Owned mutexes: HTTP(MAIN)
Last reset 00:11:43 ago, cause: power up
Last software reset at 2021-11-19 06:12, reason: User, none spinning, available RAM 141696, slot 2
Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0440f000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
Error status: 0x04Duet TOOL1LC firmware version 3.3 (2021-06-15 16:12:58)
Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
Never used RAM 2712, free system stack 2789 words
Tasks: Move(notifyWait,0.0%,153) HEAT(delaying,0.2%,117) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(delaying,2.8%,57) MAIN(running,92.0%,352) IDLE(ready,0.0%,27) AIN(delaying,4.9%,142), total 100.0%
Last reset 00:12:04 ago, cause: power up
Last software reset time unknown, reason: AssertionFailed, available RAM 3392, slot 2
Software reset code 0x0120 ICSR 0x00000000 SP 0x2000415c Task Freestk 129 bad marker1 -
Is this the same problem as your other post?
@phaedrux yes, got mixed up somewhere along the lines and a second post was created.
@thunderrunna locking this post as its a duplicate of:
https://forum.duet3d.com/topic/25995/error-invalid-remote-handle -
