My printer has stopped waiting on M109
This gcode is not working right:
; generated by PrusaSlicer 2.3.3+win64 on 2021-11-20 at 22:14:21 UTC ; ; external perimeters extrusion width = 0.45mm ; perimeters extrusion width = 0.45mm ; infill extrusion width = 0.45mm ; solid infill extrusion width = 0.45mm ; top infill extrusion width = 0.45mm ; external perimeters extrusion width = 0.45mm ; perimeters extrusion width = 0.45mm ; infill extrusion width = 0.45mm ; solid infill extrusion width = 0.45mm ; top infill extrusion width = 0.40mm M107 ;TYPE:Custom ; printer start gcode for delta M80 ; power on ; set temperatures M140 S60 ; set target bed temperature M104 S215 ; set target nozzle temperature ; home printhead G28 ; home ; wait until nozzle temperature reached and retract some filament to limit ooze M109 S215 ; wait for nozzle temperature M83 ; extruder to relative G1 E-5 F120 ; retract 5mm slowly ; in case bed not there yet M190 S60 ; wait for bed temperature ; bring print head to front to allow manual check then do bed level G1 F9000 ; fairly fast moves G1 X0 Y-120 Z100 ;E (exclude from layer analysis) G4 S2 ; wait 2 seconds - might limit oozing G32 ; auto calibrate G29 ; mesh bed levelling
The bed was already at temperature when this job started and the printer immediately generated a 'Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault' (I assume from the extrude at line 29), and went straight into the auto-calibrate at line 36.
That is, it's ignoring entirely the
at line 27.The temperatures apparently report correctly:
Here I set the print running at 22:32:12 ish, it immediately generated the warning (presumably it tried to extrude), you can see it finished the calibrate at 22:23:56, even though at that point it hadn't got to 150 degrees yet and it was supposed to have not even started that process until it got to 215. Then I cancelled the print.
I upgraded my PrusaSlicer yesterday as I moved from using a linux machine to a Windows machine, and changed some config in the slicer, but no changes to my config.g. It has been doing this since, but I can't see anything wrong with the gcode - any suggestions what I am missing?
I should have said:
Board: Duet 3 MB6HC (MB6HC)
DSF Version: 3.3.0
Firmware: RepRapFirmware for Duet 3 MB6HC 3.3 (2021-06-15)
With SBC (Pi4)However, I've re-written my start gcode with G10 and M116 and the first print has started OK with the requisite waiting for temperatures.
I have noticed some PrusaSlicer line ending oddities.
If I paste text with just LF it runs all the lines together into one, but then if I manually split the lines up in the PrusaSlicer input box, leave that pane and return to that pane all the lines are double-spaced. Some text that's consecutive lines in the PrusSlicer box appears in the gcode file with blank lines between. I did wonder if my pasted text was getting soem whitespace or line break characters such that the M109 being seen by the printer as being the continuation of a comment line, but the gcode files that misbehaved looked OK.I've typed my new gcode from scratch into the box and reduced the number of my comments and it seems OK (on the first print).
Aargh! Spoke too soon.
This job went direct to auro-calibrate, with no waiting at all:
; generated by PrusaSlicer 2.3.3+win64 on 2021-11-21 at 13:17:59 UTC ; ; external perimeters extrusion width = 0.45mm ; perimeters extrusion width = 0.45mm ; infill extrusion width = 0.45mm ; solid infill extrusion width = 0.45mm ; top infill extrusion width = 0.45mm ; external perimeters extrusion width = 0.45mm ; perimeters extrusion width = 0.45mm ; infill extrusion width = 0.45mm ; solid infill extrusion width = 0.45mm ; top infill extrusion width = 0.40mm M107 ;TYPE:Custom ; printer start gcode for delta IMS M80 ; power on G21 ; set units to mm G90 ; use absolute coordinates M140 S60 ; set target bed temperature G10 S215 ; set target nozzle temperature G28 ; home M116 ; wait for all temperatures G1 F9000 ; set speed G1 X0 Y-120 Z300 ; move head to front G4 S2 ; wait 2 seconds G32 ; auto calibrate G29 ; mesh bed levelling G1 X0 Y-120 Z300 ; move head to front M83 ; relative extruder G1 E20 F120 ; extrude 20mm to prime G10 ; standard retract (according to last print) G4 S6 ; wait 6 seconds G1 X0 Y0 Z10 ; near bed centre ;;;
And here's the temperature graph, no sign of any glitches that might make it think it was at temperature:
Does anyone have any idea why it might not wait for temperatures?
If I add echos to try and work out what is going on, this behaves as it should:
; generated by PrusaSlicer 2.3.3+win64 on 2021-11-21 at 13:17:59 UTC ; ; external perimeters extrusion width = 0.45mm ; perimeters extrusion width = 0.45mm ; infill extrusion width = 0.45mm ; solid infill extrusion width = 0.45mm ; top infill extrusion width = 0.45mm ; external perimeters extrusion width = 0.45mm ; perimeters extrusion width = 0.45mm ; infill extrusion width = 0.45mm ; solid infill extrusion width = 0.45mm ; top infill extrusion width = 0.40mm M107 ;TYPE:Custom ; printer start gcode for delta IMS echo "start" M80 ; power on G21 ; set units to mm G90 ; use absolute coordinates echo "units set" M140 S60 ; set target bed temperature G10 S215 ; set target nozzle temperature echo "temperatures set" G28 ; home echo "homed" M116 ; wait for all temperatures echo "finished waiting" G1 F9000 ; set speed G1 X0 Y-120 Z300 ; move head to front echo "head forward" G4 S2 ; wait 2 seconds G32 ; auto calibrate G29 ; mesh bed levelling G1 X0 Y-120 Z300 ; move head to front M83 ; relative extruder G1 E20 F120 ; extrude 20mm to prime G10 ; standard retract (according to last print) G4 S6 ; wait 6 seconds G1 X0 Y0 Z10 ; near bed centre ;;;
@achrn This is what I use for the start g-code, only have one hotend:
T-1 ; deslect T0
M98 P"/macros/PLAOffset" ; set z probe offset
G10 P0 S[first_layer_temperature] R140
M190 S[first_layer_bed_temperature]
G28 ; home all axes
G32 ; bed calibration
T0
M116
G1 E2 ; extrude a bit -
Can you please share your full config.g and a sliced gcode file as uploaded files?
@phaedrux I think that either of the snippets of gcode above (which don't contain any actual printing) will work as full gcode files that demonstrate the problem, because the problem occurs before any actual printing - it moves straight on as if the M109 or M116 was not there.
However, here's a third file that does the same. This one has some actual printing (though it's made-for-the-occasion, one single rectangular block). This goes straight to the
G1 X0 Y-120 Z300
completely ignoring theM116
two lines before.If I put some 'echo's in the start gcode (as above) it works fine. This works, and waits until temperatures are reached:
config.g (no changes on this for months, and up until a fews days ago it was working):
config.gSo I have a workaround - just add some echos to my slicer start gcode. However, I don't think it shoud do this.
@achrn the problem with your example (block40_no_wait.gcode) is that you have no tool selected at the point that you have the M116 command. So there is no tool to wait for, only the bed heater.
@dc42 thanks, but I'm confident it's not that:
There is a 'T0' at the end of config.g.
Why does adding two 'echo' statements make it work?
This one fails too, and I've added a T0:
block40_no_wait_withT0.gcode -
@achrn your G10 S215 command is lacking a P parameter.
btw this isn't relevant to the M109 behaviour, because M109 will select a tool implicitly if necessary.
@dc42 Thanks. I've added a P0 to my S215 and it makes no difference (that I can discern).
This is the (latest) file that does not wait:
block40_no_wait_withT0_addP0.gcodeHere's the DWC screen while the printer is doing the calibration moves, i.e. after it has supposedly received a M116.
It has identified T0, set it to 215C, and not waited.The console, a little while later:
The print starts at 12:36:24. The nozzle priming fails (because at 12:37:46 it was still too cold - see below), and then I cancelled it.The temperature graph after I cancel
This file (which uis identical except I have added the line
echo "T"
with a text editor) works perfectly:
block40_no_wait_withT0_addP0_addecho.gcode -
@achrn I have tested this on my setup as best i could quickly and cannot recreate the fault with the block40_no_wait_withT0_addP0.gcode
I had to comment out some elements so the code i ran was:M107 ;TYPE:Custom ; printer start gcode for delta IMS ;M80 ; power on T0 G21 ; set units to mm G90 ; use absolute coordinates M140 S60 ; set target bed temperature G10 P0 S215 ; set target nozzle temperature ;G28 ; home M116 ; wait for all temperatures G1 F9000 ; set speed G1 X0 Y-120 ; move head to front G4 S2 ; wait 2 seconds ;G32 ; auto calibrate ;G29 ; mesh bed levelling G1 X0 Y-120 ; move head to front M83 ; relative extruder G1 E20 F120 ; extrude 20mm to prime
Can you also try commenting out the home command in between temperature setting and M116 and see if the wait works in that case. (home your printer before hand so its safe).
Cheers
@t3p3tony Thanks for testing.
With all teh identified items except the home immediately after setting temperatures commented out, it shows the same behaviour - doesn't wait for temperature, now tries to start printing immediately so I get lots of 'not driven' messages:
block40_no_wait_withT0_addP0_adj.gcode
gives
My workflow was:
- use ATX power on button on DWC dashboard (this switches on my 24V - the duet itself has external 5V supply)
- use home all button on DWC dashboard
- select delta calibration from DWC dashbvaord
- select run mesh compensation from DWC dashboard
- issue
G1 Z200
via box in top window border - pick the file from Files - Jobs in DWC
However, if I comment out that G28 command, i.e.
and otherwise as above, then it works OK and waits. I've also tried it both with the G28 commented out and with the G28 line completely removed. Both work the same (i.e. work OK - the printer waits for temperatures).
I've tried various combinations of resets and print sequence - e.g.
- M999 then one with the G28 in place fails
- M999 then one without the G28 goes OK
- M999, then without G28 (goes OK) then one with the G28 fails
- M999, then with G28 (fails), without G28 (goes OK), then with G28 (fails)
So as far as I can make out, having the G28 after setting the temperatures and before the M116 causes a fail (no waiting), but having a G28 and an echo (even of only one character) works OK (it waits).
@achrn thanks for confirming that. Can you post your homeall.g and any of the files that it calls.
@t3p3tony I must admit it didn't occur to me to look into that!
I don't have a homeall.g, it's a delta and I have a homedelta.g.As it happens, I don't see anything that I think would upset it:
; homedelta.g ; called to home all towers on a delta printer ; ; M80 ; drive power on G4 S1 ; wait one second for power to stabilise G91 ; relative positioning M913 X50 Y50 Z50 ; set X Y Z motors to 50% of their normal current G1 H1 X750 Y750 Z750 F1800 ; move all towers to the high end stopping at the endstops (first pass) G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm G1 H1 X10 Y10 Z10 F240 ; move all towers up once more (second pass) more slowly M913 X100 Y100 Z100 ; motors back to normal current for full speed moves G1 Z-5 F10000 ; move down a few mm so that the nozzle can be centred G90 ; absolute positioning G1 X0 Y0 ; centre
@achrn thanks. Can you do me a favour and try inserting the contents of those commands into the test print, in place of G28. If that does not work try commenting out the
G4 S1
. I am not sure but of all the commands that's the only one that's less frequently seen in a homing file AFAIK so its top candidate for the cause of this issue. -
My printer has been physically off all day (real life intruded). Now I've copied the previous file as it was (i.e. known bad behaviour), power on the duet, use ATX power on manually, run delta calibration manually, lifted the head to z=200, sent the file, and it fails to wait. So far this is as previously tested (just a change in filename).
block40_no_wait_adj.gcode
homedelta.gThen I've copied that file and removed the G28 replacing it with the full code content of my homedelta.g (but not the comments on lines by themselves). That gives me
block40_no_wait_adj_ noh1.gcodeIf I follow the same workflow (ATX power on, delta calibration, G1 Z200, send file) it honours the M116 and waits for temperatures to hit the specified values.
Repeating the exercise with the suspect
G4 S1
removed seemed to be something to try in the event that the option above still didn't wait. However, I've tried it anyway.
block40_no_wait_adj_ noh2.gcodeIf I follow the same workflow, this also waits for temperatures to hit the specified values.
For completeness I've then returned to the file at the top of the page and followed the same workflow again, and it still doesn't wait for temperatures to be reached.
Would you be willing to upgrade to the 3.4 beta on the unstable branch to test the most recent code to see if the issue remains?
See here for switching to and from the test branch on the pi.
https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation -
@phaedrux 3.4.0b6 works as I think it should, i.e. the file block40_no_wait_adj.gcode from my posting yesterday now does wait for the temperatures to reach the commanded values before proceeding with the rest of the file.
I did try a full update of the pi (i.e. sudo apt update; sudo apt upgrade;) but remaining at 3.3 first, and that made no difference - still didn't wait.
Having upgraded to 3.4b6, I had to change my config.g to define a pin in my M81 command but otherwise made no changes to eitehr config or the print file and my file works.
Thanks.
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
Thanks for testing and verifying that it works correctly in 3.4b6
