    Duet delta prints mirror image
    • opentoideasundefined
      opentoideas
      ok this will be obvious I am sure but I have just realised that the prints from my delta are a mirror image of the model that I slice.
      I didnt notice as the parts I have printed were not handed but printing a fan shroud its obvious as the blower fan mounts the opposite way. on my delta shroud I have 3 diferent faces that on the model run clockwise 123 but when printed they are 321 if that makes sense.
      whats wrong??
        Sounds like you have your coordinate system flipped.
        I would suggest going back to basics and running through the delta setup and calibration guides.
        https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter
        https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
        Make sure your towers are where they should be.
        opentoideasundefined 1 Reply Last reply Reply Quote 0
          opentoideas @Phaedrux
          @phaedrux yup thats sounding right I had the same with Z and thought I had it figured out.
          Time to try again
            opentoideas
            Swapped the x and y motors and endstops and think thats fixed it. Thanks again for the pointer.
            I think I went clockwise not anticlockwise when I first added the Duet.
            • droftartsundefined droftarts marked this topic as a question
            • droftartsundefined droftarts has marked this topic as solved
