    Missing macros in RRF Config Tool
    Config Tool
    453
    • Falkiaundefined
      Falkia
      Using the RRF config tool (to set up my Delta printer (Duet 2 WiFi, FW 3.3 or later). Going through all the tabs and downloading the files.
      But the sys folder in the config.zip file only contains config.json and tpost0.g.
      I thought that all the needed macros should be created this way?
      Thanks
      Fredrik
      Printer: "Deltacus" Delta with 510mm bed diameter and 925mm build height. Powered by Duet 2 WiFi. Duet Smart Effector with E3D Volcano.
      FrankVundefined 1 Reply Last reply Reply Quote 0
        Strange. When i download the zip file it appears the files are there, but the file extension has a question mark at the end.
        57f47108-7cc4-420c-8c00-e76be08e7ec1-Screen Shot 2021-11-25 at 2.30.30 PM.png Screen Shot 2021-11-25 at 2.30.30 PM.png
          Thanks for reporting that. Will bring it up for @chrishamm
          Falkiaundefined 1 Reply Last reply Reply Quote 0
          • Falkiaundefined
            Falkia @Phaedrux
            @phaedrux this was strange. When opening the zip file with the windows built in function I can only see two files (config.json and tpost0.g) but when opening the same file with 7-zip, all macros are there but the filenames ends with _.
            chrishammundefined 2 Replies Last reply Reply Quote 0
            • chrishammundefined
              chrishamm administrators @Falkia
              @falkia Thanks for reporting this, can you please share your config.json file so I can attempt to reproduce it?
              Duet software engineer
              Falkiaundefined 2 Replies Last reply Reply Quote 0
              • Falkiaundefined
                Falkia @chrishamm
                @chrishamm config (1).json
                • Falkiaundefined
                  Falkia @chrishamm
                  @chrishamm, I setup the network with SSID and password and static IP address in the config tool but that's missing in the config.g.
                    @falkia Odd, I can confirm Windows Explorer doesn't show all the files from 0:/sys whereas WinRar does. I'll have a look at this.
                    Your network settings are stored in runonce.g because WiFi networks are configured only once using M587.
                    • FrankVundefined
                      FrankV @Falkia
                      @falkia there are more people where the files are not in the zip. I think someting is going wrong at the moment. I am a new user so I don't know how it's normal. I get only a json config file.
                      • FrankVundefined
                        FrankV @chrishamm
                        @chrishamm I do have same problem. With winrar I get g_ as result. In explorer files are not visible. When used in the webgui for upload. I get all sorts of error. So for now I need to use winrar. Rename all files and upload them. There is def. someting broken.
                          @falkia The new ConfigTool version 3.3.7 should fix this. Please force-reload the website using Ctrl+Shift+R if it still displays 3.3.6 at the bottom.
                          • Falkiaundefined
                            Falkia @chrishamm
                            @chrishamm Yes the new config tool works (version 3.3.9).
                            Thanks
                            Fredrik
                            • Falkiaundefined Falkia marked this topic as a question
                            • Falkiaundefined Falkia has marked this topic as solved
