    bed mesh problem with Delta after upgrade to 3.3 from 2.05_1
    403
    • Baenwortundefined
      Baenwort
      I've upgrade my SeeMeCNC Rostock v3.2 from firmware 2.05 to 3.3 following the normal guides. Everything is working properly (and I'm able to complete prints) when I just use G32 for the auto cal.
      This is a older printer that is nearing the end of it's life so the best correction I can get is around 0.03 to 0.05 after a pair of S8 G32 runs.
      However, when I run a G29 to do a bed mesh I get the error:
      When I check the height map this is what I see:
      I do not home (28) at the end of my bed.g and I have it set to run a autocal and then directly the G29.
      When I let it try to print with the mesh active it does bed dive and try to reach a point below the print surface.
      Any ideas?
      11/28/2021, 2:27:30 PM	M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet Ethernet 1.02 or later
      Board ID: 08DGM-917NK-F2MSW-6JKDG-3S86S-KZ5JD
      Used output buffers: 1 of 24 (18 max)
      Static ram: 23876
      Dynamic ram: 70544 of which 0 recycled
      Never used RAM 19996, free system stack 116 words
      Tasks: NETWORK(ready,29.8%,229) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,303) MAIN(running,70.1%,128) IDLE(ready,0.0%,29), total 100.0%
      Owned mutexes:
      Last reset 00:52:52 ago, cause: software
      Last software reset at 2021-11-28 13:34, reason: User, GCodes spinning, available RAM 17348, slot 1
      Error status: 0x00
      Step timer max interval 0
      MCU temperature: min 15.4, current 16.9, max 18.0
      Supply voltage: min 14.2, current 14.5, max 14.6, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 44211, standstill, SG min/max 0/783
      Driver 1: position 55653, standstill, SG min/max 0/778
      Driver 2: position 68827, standstill, SG min/max 0/804
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2021-11-28 14:27:28
      Slowest loop: 71.79ms; fastest: 0.17ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 19.2ms, write time 13.8ms, max retries 0
      DMs created 83, maxWait 184993ms, bed compensation in use: mesh, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 2253, completed moves 2253, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Heater 0 is on, I-accum = 0.7
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 41.03ms; fastest: 0.02ms
      HTTP sessions: 2 of 8
      Interface state active, link 100Mbps full duplex
      mesh.g homedelta.g config-override.g config.g bed.g
      T3P3Tonyundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • T3P3Tonyundefined
        T3P3Tony administrators @Baenwort
        here is your mesdh.g
        ; mesh.g
        M117 Bed Map - Heating Bed                              ; display message
        G28                                                     ; home
        M140 S80                                                ; set bed temp
        M190 S80                                                ; wait for bed temp
        M140 S0                                                 ; bed heat off
        G32
        M558 P8 I0 A10 S0.01 R0.4 C"zprobe.in" H8 F1500 T6000         ; HOTEND PROBEset Z probe type to switch and the dive height + speeds
        M557 R140 S14                                           ; HOTEND PROBE define mesh grid
        G29 S2                                                  ; clear height map
        G29 S0                                                  ; run mesh calibration
        M500                                                    ; save results to EEPROM
        ;G28                                                     ; home
        M375                                                    ; load heightmap
        ;M84                                                     ; motors off
        M117 End Mesh Probe Calibration                         ; display message
        You need to add G30 to probe the bed and establish a Z datum before starting the mesh
        best to do that in the center of the bed so I would add a line to move the probe to the center of the bed, then probe with a single G30 at that point, the start the mesh bed levelling
        www.duet3d.com
        Baenwortundefined 1 Reply Last reply Reply Quote 1
        • Baenwortundefined
          Baenwort @T3P3Tony
          @t3p3tony
          Per the Duet Wiki: https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation#Section_Establish_a_Z_0_datum_using_the_Z_probe the Delta AutoCalibration (G32) should produce a Z-0 and be used for Delta machines instead of G30.
          G30 isn't the recommended way to set Z height for the delta configuration as it is basically a multiple z-axis bot.
          If the Wiki is wrong I'm happy to try with a G30.
            jay_s_uk @Baenwort
            @baenwort I find its easiest to home using G28, then do a single probe with G30 and then run G32 and save the results. That gets the homed height correct. And then from there, a G32 should be all that's needed at the beginning of a print
              dc42 administrators @Baenwort
              @baenwort doing G32 immediately followed by G29 is the correct method. However, one thing I notice is that you change the probing speed (M558 F parameter) between the G32 and the G29 S0. What happens if you remove the M558 line from mesh.g so that you use the same parameters for G32 and G29?
              Also, if you are going to use G29 S2, put it before G32 instead of after.
              You don't need the M375 command in mesh.g because the height map will be loaded anyway after G29 S0.
              Phaedruxundefined Baenwortundefined 3 Replies Last reply Reply Quote 1
                Phaedrux Moderator @dc42
                @dc42 said in bed mesh problem with Delta after upgrade to 3.3 from 2.05_1:
                If you do this, remove the G29 S1 from the end of your bed.g as well.
                • Baenwortundefined
                  Baenwort @dc42
                  Thanks!
                  I'll give these a try tonight after I get the kids in bed.
                  This has been frustrating as I like my flex plate system overall but without mesh compensation it isn't as good as glass for large bed filling prints.
                  I didn't run G29 when I had just glass and a doping agent. But I find that the mag sticker and flex plate added enough nonuniformity that I need it once I get away from the center of the bed.
                  • Baenwortundefined
                    Baenwort @dc42
                    @dc42 So it seems that the F parameter being different or the G32/G29 S2 order change was what did it. I'm going to try testing tomorrow to see which of the two changes was the causative one.
                    I hope it is just the F parameter change as I'd like to keep the G29 S1 load in the bed.g as I run a G32 before every print and I'd rather not forget a G29 S1 load.
                    Baenwortundefined 1 Reply Last reply Reply Quote 0
                    • Baenwortundefined
                      Baenwort @Baenwort
                      So I tried with only the F change and it fixed it. The G29 S2 positioning did not affect the mesh to cause the problem I am seeing.
                        @baenwort said in bed mesh problem with Delta after upgrade to 3.3 from 2.05_1:
                        I'm glad you solved it. I think what's happening is that the trigger height depends on the probing speed, at least at high speeds, because of the response characteristics of the sensor.
                        • dc42undefined dc42 marked this topic as a question
                        • Baenwortundefined
                          Baenwort @dc42
                          Seems so. It is a Duet Smart Probe based system from SeeMeCNC. Being a strain probe I expected maybe some difference but this was a rather large difference in results.
                          It makes me think I might want to spend some time tuning the F parameter.
