    Adjusting Device Wattage conditionally
    Gcode meta commands
    • code7undefined
      code7
      I run a macro that sets the device power (i.e. lasers etc.) on my machine using M106 P2 S25, where S25 sets the device power on a scale from 0-255.
      Does anyone have a goood idea on how I can can instead control the power with a conditional statement by indicating the desired wattage by % of full power instead - where full power is 400W of the device?
      Delta Printer Using a Duet 2 Wifi v1.04c, FW3.4.0beta2, Duet WiFi sever 1.26, Duet Web Control 3.3.0
      alankilianundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
      • alankilianundefined
        alankilian @code7
        @code7 You can use M106 P2 0.0 to M106 P2 1.0 to set what fraction you want.
        M106 P2 S0.5 would be 50% power.
        • o_lampeundefined
          o_lampe @code7
          @code7
          Using a macro can cause a short delay, everytime you set a new power value.
          If that's OK for you, you can use macros with parameters. Eg. P0-P100. Then in the macro calculate the M106 Pn S-value accordingly
          code7undefined 1 Reply Last reply Reply Quote 1
          • code7undefined
            code7 @o_lampe
            @alankilian That's a great tip - Thanks.
            @o_lampe Thanks for the link.
