SD card physically broken
I ended up breaking my SD card in to two pieces. I did not make a back up of the sd card. I have a Duet 2 wifi board that I always controlled and updated through the web interface. Is there any way to recover the config file or anything? I have a custom setup and have made so many changes and tweeks to it that it really is heart breaking to have to start over from scratch again. Any help would be appreciated. Thank you
@rogerz79 unfortunately not. I suggest starting with the config tool to get the basics setup and then go from there.
@t3p3tony nothing stored in a cookie or a cache of some sort on the website
@rogerz79 no unfortunately not.
How did it break in two?!
@rogerz79, for future backups, you may want to look at the Duet's rfm utility. It syncs your configuration to a computer. Also works well with versions control systems such as github.
Also, I am not sure, but DWC may be able to create backup zip files (?).
