    Layer Time Chart Bug from External Network
    Duet Web Control
    • CCS86undefined
      CCS86
      Duet Web Control 3.4.0-b2
      When viewing an active print job from a remote network, the Layer Chart appears blank until a layer completes. Then, that layer is assigned a layer time equal to the entire print time, with all previous layers showing 0s layer time. All subsequent layers show the correct layer time, but the scaling is broken by the "bad" layer.
      Phaedruxundefined T3P3Tonyundefined chrishammundefined 3 Replies Last reply Reply Quote 0
        Phaedrux Moderator @CCS86
        @ccs86 said in Layer Time Chart Bug from External Network:
        Is that still true in beta6?
        • T3P3Tonyundefined
          T3P3Tony administrators @CCS86
          can you be clearer on what you mean by a remote network. What IP is the Duet and the machine you are checking from. If this is truly "remote" i.e not on the same LAN can you see if the same issue occurs when on the same LAN.
          www.duet3d.com
          CCS86undefined 1 Reply Last reply Reply Quote 0
          • CCS86undefined
            CCS86 @T3P3Tony
            @t3p3tony Yes, I did mean remote, as in not the same LAN, hitting my external IP and port fording to the Maestro.
            I did some more testing and found the issue is repeatable even on my LAN, just by refreshing the browser page. Normally my DWC tab stays loaded for a whole print, so I didn't notice before.
            I have not tried flashing the latest beta yet.
            • T3P3Tonyundefined
              @ccs86 ahh ok, yes this is not related to the remote connection AFAIK. There is no cache on the Duet for previous layers that were printed before the DWC session connected.
              @chrishamm please can you look at why the first layer after connecting part way through a print is counted as taking the whole print time up to the point the session starts.
              www.duet3d.com
              • chrishammundefined
                chrishamm administrators @CCS86
                @ccs86 Thanks for reporting this, I've got a fix ready that will be included in 3.4-b7.
                Duet software engineer
                CCS86undefined 1 Reply Last reply Reply Quote 1
                • CCS86undefined
                  CCS86 @chrishamm
                  @chrishamm said in Layer Time Chart Bug from External Network:
                  Thanks @chrishamm, happy to help!
