Duet 3 6HC Stepper Problem driver(s) 1 2
Hello everybody im new with the duet boards. the question is I'm getting a error message when I try to check the steppers I'm building the frame at the moments so I didn't connect anything but steppers I have the Nema 17 US-17HS4401 and When I try to see the problem from the yat I get this message
Motor current (mA) - X:1400, Y:2500, Z:2500, E:1400, idle factor 30%<LF>ok<LF>Warning: motor phase A may be disconnected reported by driver(s) 3<LF>Warning: motor phase B may be disconnected reported by driver(s) 3<LF>Warning: Obsolete use of S parameter on G1 command. Use H parameter instead.<LF>Warning: motor phase A may be disconnected reported by driver(s) 1 2 5<LF>Warning: motor phase B may be disconnected reported by driver(s) 1 2 5<LF>Warning: motor phase A may be disconnected reported by driver(s) 1 2 5<LF>Warning: motor phase B may be disconnected reported by driver(s) 1 2 5<LF>Warning: motor phase A may be disconnected reported by driver(s) 1 2 5<LF>Warning: motor phase B may be disconnected reported by driver(s) 1 2 5<LF>Warning: motor phase A may be disconnected reported by driver(s) 1 2 5<LF>Warning: motor phase B may be disconnected reported by driver(s) 1 2 5<LF>Warning: Obsolete use of S parameter on G1 command. Use H parameter instead.<LF>
I get this messages from the d0 and d4 ports the others are working well at the moment. Here is my config file config.g
Verify that your motor phases are paired correctly.
@phaedrux these is no problem in phase connection when I plug the cable to the another slot its working there is no problem with the cables
If I'm reading the error messages correctly, the reports are errors on 1, 2, 3 and 5.
3 in the first message and 1,2,5 in the second.Everything in use except the extruder, in other words..
Try this, with a board number prefix, it may work differently?
It's the format I use on my (working) 6HC machine:M584 X0.5 Y0.1:2 Z0.3 E0.4 ; set drive mapping -
@rjenkinsgb Hello Robert thanks for your answer unfortunately it didn't work for me. I unplug all the slots except the driver 0 and the driver 4 slots as I said these are the slots with problems the others are working at the moment I still control them
@ertence said in Duet 3 6HC Stepper Problem driver(s) 1 2:
Can you clarify that?
The reports are errors on 1, 2, 3 & 5 which you appear to be saying are unplugged.With no motor connected but an output configured, surely errors for those [disconnected] motors are to be expected??
What happens when all motors are properly connected?
