So, who will design a LGX lite mount?
I'd be curious to try this one as a direct extruder with smart effector. But, I am starting to realise that my CAD skills are .. slightly below mediocre. Hence I thought I'd check if someone was working on this.
@janjoh yeah I will be, although I only got my order in yesterday and the delivery estimate is early January. I'll share whatever I create on here and in the usual repositories.
@slimshader said in So, who will design a LGX lite mount?:
I Ordered it without motor. Found same LDO-motor in Poland. Funny enough the cost + shipping was just a cpl of euros more then the standard listing price on Bondtech.
The distance between filament path and motor-backplate is pretty large (compared to Sherpa Mini)
From my experience the motor will foul the rods or the magnet-sleeves pretty soon.
I've designed an 8mm offset effector to make the Sherpa Mini fit between the rod spacing of theSmart Effector.
The LGX lite will need even more offset or a bigger rod-distance.
The motor just fits at 100mm radius
