    Short to ground reported by driver
    • r.perezdominguezundefined
      r.perezdominguez
      Hi - I am getting a “Short to ground reported by driver” error message - Wiring look all good and I can’t see any problem on the board (Duet 3 mini5+ Ethernet). All the wiring is set as per the instructions plus a 12v fan I wired to the always on 12v supply on the middle of the board. Got the message while configuring the endstop for driver 0 (mapped to the C axis in my machine) but I do not think this is the source of the problem. I am running the most recent firmware available.
      My config.g file is below (in my installation I have the configuration separated in several files, I find easy to split code by themes; have compiled all in one file here)
      ; Configuration file for Duet mini5+
      ; M98 P"config-network.g"
      ; Network configuration executed by config.g
      ; Configure Connection - ENABLE ONLY ONE OF THE BELOW THREE
      ;M552 S1 ; Enable Wifi Network
      ;M552 S2 ; Enable Access Point Mode
      M552 S1 P192.168.2.1 ; Enable Ethernet - set IP Address to suit HP
      M553 P255.255.255.0 ; Set Net mask
      ; Network settings
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      ; Set Network machine name
      M550 P"CNC-Butterfield"
      ; M98 P"config-drives.g"
      ; Drive configuration executed by config.g
      ; Axes steppers directions, P refers to the driver and S refers to the direction (0=clockwise or 1=anticlockwise)
      M569 P0 S0 ; Drive 0 axis x goes right, from origen
      M569 P1 S1 ; Drive 1 axis y1 goes forwards
      M569 P2 S0 ; Drive 2 axis z goes up
      M569 P3 S1 ; Drive 3 axis y2 goes forwards
      ; M98 P"config-axes.g"
      ; Axes configuration executed by config.g
      ; drive mapping to axes
      M584 X0 Y1:3 Z2 ; Apply mapping to axes
      M584 P3 ; 3 is the number of axes
      ;M584 X0 Y4 Z2 E3 ;remap driver Y to driver E1
      ;M569 P0 S1 ; Drive 0 goes forwards
      ;M569 P1 S1 ; Drive 1 goes forwards
      ;M569 P2 S0 ; Drive 2 goes forwards
      ;M569 P3 S1 ; Drive 3 goes forwards
      ;M569 P4 S1 ; Drive 3 goes forwards
      ; sets motor currents (mA), set this to 80% max rated current - I is Idle factor 30%
      M906 X2000 Y2000 Z2000 I400
      ; sets the steps per mm axis travel
      M92 X400 Y400 Z400 ; Set steps per mm
      ; sets microstepping, 1 is full step, 16 is 1/16 step, I is microstep interpolation 1=Enable
      M350 X16 Y16 Z16 I1
      ; sets the maximum speed (mm/min) useful to prevent damage if axis aproach its limits
      M203 X2500 Y2500 Z2500
      ; sets accelerations (mm/s^2) - the higher the number the quicker the steppers get to their set speeds
      M201 X150 Y150 Z150
      ; sets the max instantaneous speed change (mm/min)
      ; optimise or machine could rattle itself apart or become too slow when cutting curves
      M566 X500 Y500 Z500 ; Set maximum instantaneous speed changes
      ;sets kinematics type and kinematics parameters, k 0 = Cartesian
      M669 K0 X1:0:0:0 Y0:1:0:1 Z0:0:1:0
      ; M98 P"config-axes-limits.g"
      ; Axes Limits configuration executed by config.g
      M208 X0 Y0 Z0 S1 ; 1 Set axis minima - xyz origen
      M208 X500 Y600 Z90 S0 ; 0 Set axis maxima, positions assumed when an endstop is triggered
      ; M98 P"config-axes-calibration.g"
      ; Axes Calibration configuration executed by config.g
      ; M98 P"config-axes-endstops.g"
      ; Endstop configuration executed by config.g
      ; sets position of endstop sensor on axis with 1 = low axis end
      ; S sets the endstop sensing type 0 = active low endstops
      ; M574 X2 Y2 Z2 S0
      M574 X2 P"!io0.in" S1
      M574 Y2 P"!io1.in" S1
      M574 Z2 P"!io3.in" S1
      ; Other Settings
      M453 ; Put the machine into CNC Modes
      G90 ; Set absolute coordinates
      M140 H-1 ; Disable heated bed
      M564 S1 H1 ; Disable jog commands when not homed
      ;M564 S1 H0 ; use for disabled jog commands
      M911 S21.0 R23 P"G91 G1 Z3 F1000" ; Configure power loss resume
      ; User Configuration files
      ; M98 P"config-user-settings.g"
      ; Additional user settings executed by config.g
      M564 S1 H0
      M501 ; Load Stored Parameters
      Running M122 I got:
      M122
      RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus Ethernet (standalone mode)
      Board ID: 9H0Q1-W396U-D65J0-40KM8-M313Z-HH9AB
      Used output buffers: 3 of 40 (11 max)
      Static ram: 102724
      Dynamic ram: 99760 of which 0 recycled
      Never used RAM 41220, free system stack 200 words
      Tasks: NETWORK(ready,27.0%,280) ETHERNET(notifyWait,0.1%,572) HEAT(delaying,0.0%,406) Move(notifyWait,0.1%,362) CanReceiv(notifyWait,0.0%,941) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,332) TMC(delaying,0.7%,106) MAIN(running,71.3%,504) IDLE(ready,0.0%,29) AIN(delaying,0.8%,264), total 100.0%
      Owned mutexes:
      Last reset 01:10:47 ago, cause: software
      Last software reset at 2021-12-10 19:04, reason: User, GCodes spinning, available RAM 41220, slot 0
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      MCU revision 3, ADC conversions started 4248031, completed 4248030, timed out 0, errs 0
      Step timer max interval 1487
      MCU temperature: min 17.2, current 17.9, max 18.6
      Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 26944, writes 9, timeouts 0, DMA errors 0
      Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 26944, writes 9, timeouts 0, DMA errors 0
      Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 26944, writes 9, timeouts 0, DMA errors 0
      Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 26944, writes 9, timeouts 0, DMA errors 0
      Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 26944, writes 9, timeouts 0, DMA errors 0
      Driver 5: position 0, assumed not present
      Driver 6: position 0, assumed not present
      Date/time: 2021-12-10 20:14:56
      Slowest loop: 5.95ms; fastest: 0.11ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.8ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters = -1 -1, chamberHeaters = -1 -1
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === CAN ===
      Messages queued 21240, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17), ts 21240/0/0
      Tx timeouts 0,0,21239,0,0,0 last cancelled message type 30 dest 127
      === Network ===
      Slowest loop: 4.37ms; fastest: 0.03ms
      HTTP sessions: 1 of 8
      • Ethernet -
        State: active
        Error counts: 0 0 0 0 0
        Socket states: 5 2 2 2 2 0 0 0
      Any ideas as to what might be the problem?
      Cheers
      Rafa
      • T3P3Tonyundefined
        T3P3Tony administrators @r.perezdominguez
        @r-perezdominguez which driver is having the short to ground error? Do you get the error with no motor plugged in?
        www.duet3d.com
        r.perezdominguezundefined 2 Replies Last reply Reply Quote 0
          r.perezdominguez @T3P3Tony
          @t3p3tony It’s Driver 0, got the error with the motor plugged in. Twice got the error. Prior to that the motor was operating okay.
            @t3p3tony Have done more tests - Essentially disconnected the motors from drivers 0 and 1 and switched the machine on. No errors showing without motors - next I powered all off and connected back the motors. After all was connected I switched all back on and now the motors spins normally and no errors. Axes all moving smoothly and apparently all is now as it was initially. Only difference is that I am now controlling the board via the same laptop but this time it is running on battery power only. Can’t understand - has anyone experienced something similar? I.e. an intermittent driver error
            Cheers
            R
              Phaedrux Moderator @r.perezdominguez
              @r-perezdominguez said in Short to ground reported by driver:
              There would be potential for a USB ground loop.
              https://duet3d.dozuki.com/Wiki/USB_ground_loops
              It's also possible it was a bad crimp or connection at the motor?
              r.perezdominguezundefined 1 Reply Last reply Reply Quote 0
                r.perezdominguez @Phaedrux
                @phaedrux All sorted now- likely to have been a bad connector. Many thanks for the help. R
