    min. Temperature setting of the nozzle is too high
    • marklerundefined
      markler
      Hello all,
      I am using a Duet2 wifi board. I got a filament that processes in the 120 - 150 °C range. Unfortunately, the current firmware cannot do this. Is it possible to change the min. value? Thank you very much for your help.
      Greetings Maerkler
      OwenDundefined engikeneerundefined 2 Replies Last reply Reply Quote 0
      • OwenDundefined
        OwenD @markler
        @markler
        If you mean the preset values in DWC and/or PanelDue, both can be configured in the settings.
        Put whatever values you want in there.
        You can also send whatever temp you want in your gcode
        The slicer would normally add this.
        • engikeneerundefined
          engikeneer @markler
          @markler you want to look at M302
          https://duet3d.dozuki.com/Wiki/M302
          You can set the lowest extrude temperature (160C by deg), or just allow cold extrusion
          i3 clone with a bunch of mods
          • marklerundefined
            markler
            Many thanks OwenD and engikeneer , yes the M302 command was the one I was looking for. Thanks
