    Which emulation to use with PE Slic3r
    499
    • Captain_squndefined
      Captain_sq
      I use the 2.3.3 Prusa slic3r together with a Duet Wifi (2.05.1). If I choose the FW emulation "Marlin" both in PE Slic3r and in the Duet config.g I get strange behaviour; motors moving extremely slow. The only working combination of these settings - were it behaves like expected - seems to be RepRapFirmware in PE Slic3r and Merlin in the Duet config. Like this :
      M555 P2 		; Set firmware compatibility to look like Marlin
      Is there an explanation for this?
      Best regards /Thom
      Custom made Kossel Mini - Duet WiFi / Modded Tronxy X5S - Duet WiFi / Prusa i3 MKIII
      Embedded systems designer, RC Pilot, maker and Gadget-o-holic
      • oliofundefined
        oliof
        if you use acceleration control with PrusaSlicer it sets the values assuming mm/sec; RRF expects mm/min ..... so disable acceleration control and you should be fine. Or use the fork by @bot
        botundefined 1 Reply Last reply Reply Quote 3
        • botundefined
          bot @oliof
          @oliof Thank you for the mention.
          I'm going to upload a new release shortly with some Prusa-side bug fixes, and a few colour clean-ups. I'll post the link here when I do, or find my thread on the forum.
          oliof, are you using -n8 edition? How do you like the colours? are there any changes you would think of, or problems you have encountered?
          As for the topic at hand -- stock PrusaSlicer isn't too bad with RepRapFirmware. It's likely as oliof suggested, the acceleration control or other speed related setting mm/sec mm/min mismatch.
          Cheers!
          *not actually a robot
          oliofundefined 1 Reply Last reply Reply Quote 1
            Phaedrux Moderator @Captain_sq
            @captain_sq said in Which emulation to use with PE Slic3r:
            This is used for USB response acknowledgement format and nothing more.
            The slicer should be set to reprapfirmware gcode flavor.
            Captain_squndefined 1 Reply Last reply Reply Quote 1
            • oliofundefined
              oliof @bot
              @bot I'm using a completely different slicer in day to day.
                Captain_sq @Phaedrux
                @phaedrux said in Which emulation to use with PE Slic3r:
                Interesting. I use the Duet over WiFi as mentioned. Does the M555 command affect anything at all in this scenario?
                  No. It's often misunderstood.
                  Captain_squndefined 1 Reply Last reply Reply Quote 0
                    Thanks for clarifying that. /T
