after print part orientation change
@patel said in after print part orientation change:
@phaedrux
Yes red dot end stop switchIf that's the case, then then endstop definition should be X at low end (M574 X1) Y at high end (M574 Y2) and the homing moves should change to have X move negative to the left and Y move positive to the back.
If those movement directions are no correct, then the motor rotation may need to change in M569. https://duet3d.dozuki.com/Wiki/M569
@phaedrux
Know ok
Thank you again for helping me -
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
