    printer doesn't pause when there is a heater fault
    • aprzundefined
      aprz
      My printer was almost done with a print and the heater fault was displayed but continued printing with out filament extruding because the heaters were at 0 Celsius. I was trying to figure out how to activate the auto pause when heater fault is displayed but could not figure out what was needed. Any help would be appreciated. I'm currently recalibrating heater so will update that but heater fault should cause printer to pause right? Thanks for the help in advance.
      Duet 3 and DWC 3.3.0
      G90                                                     ; send absolute coordinates...
      M83                                                     ; ...but relative extruder moves
      M550 P"Duet 3"                                          ; set printer name
      ; Wait a moment for the CAN expansion boards to start
      G4 S2
      ;M552 P0.0.0.0 S1        ; enable network and acquire dynamic address via DHCP
      ;M586 P0 S1        ; enable HTTP
      ;M586 P1 S0        ; disable FTP
      ;M586 P2 S0        ; disable Telnet
      M569 P1.2   S1        ; X axis physical drive 0.4 goes forwards
      M569 P2.2   S1        ; X axis physical drive 0.5 goes forwards
      M569 P2.0   S1        ; Y axis physical drive 2.0 goes forwards
      M569 P2.1   S1        ; Y axis physical drive 2.1 goes forwards
      M569 P1.1   S0        ; Y axis physical drive 1.1 goes forwards
      M569 P1.0   S0        ; Y axis physical drive 1.3 goes backwards
      M569 P0.0   S1        ; Z axis physical drive 0.0 goes forwards
      M569 P0.1   S1        ; Z axis physical drive 0.1 goes forwards
      M569 P0.2   S1        ; Z axis physical drive 0.2 goes forwards
      M569 P0.3   S1        ; Z axis physical drive 0.3 goes forwards
      M569 P20.0  S0        ; Tool 1 physical drive 20.0 goes forwards
      M569 P21.0  S1        ; Tool 2 physical drive 21.0 goes forwards
      M569 P0.4   S0        ; Tool 2 physical drive 0.4 goes forwards
      M569 P0.5   S0        ; Tool changer coupler Physical drive 0.5 goes forwards
      M584 X1.2:2.2 Y2.0:2.1:1.1:1.0 Z0.0:0.1:0.2:0.3 C0.5 E20.0:21.0:0.4           ; Four Z motors connected to driver outputs Z axis
      M671 X-30:-30:890:890    Y-30:890:890:-30  S3                               ; leadscrews at rear left, front left, front right, rear right (connected to Z)
      M208 X0:820 Y0:820 Z0:800 C0:360                                              ; X axis moves from 0 to 845, Y axis goes from 0 to 840, Z Moves from 0 to 800, C moves from -45 to 360
      M350 X16      Y16      Z16       C16        E16:16:16  I1                     ; configure microstepping with interpolation
      M92  X80.00  Y160.00  Z3200.00  C91.022    E837.00:837.00:760.00             ; set steps per mm
      M566 X70.00   Y70.00   Z270.00   C2         E7000.00:7000.00:7000.00          ; set maximum instantaneous speed changes (mm/min)
      M203 X7250.00 Y7250.00 Z350.00   C5000      E10000.00:10000.00:10000.00       ; set maximum speeds (mm/min)
      M201 X90.00   Y90.00   Z270.00   C500       E8000.00:8000.00:8000.00          ; set accelerations (mm/s^2)
      M906 X3200    Y1800    Z2300     C600       E990:990:500  I30                 ; set motor currents (mA) and motor idle factor in per cent
      M84  S30        ; Set idle timeout
      ;M208 X0:845 Y0:890 Z0:800 C0:360                                              ; X axis moves from 0 to 845, Y axis goes from 0 to 840, Z Moves from 0 to 800, C moves from -45 to 360
      ; Filament sensors
      M591 D0 P1 C"20.io1.in" S1                                                    ; filament monitor connected to pin 20.io1.in
      ;M591 D1 P1 C"21.io1.in" S1                                                    ; filament monitor connected to pin 21.io1.in
      ;M591 D0 P1 C"0.io3.in"  S1                                                   ; filament monitor connected to pin 3.io3.in
      ;Extra sensor
      M308 S10 Y"mcu-temp" A"MCU"
      M574 X1 S1 P"2.io2.in"                                       ; configure active-low endstop for low end on X via pin 2.io2.in
      M574 Y1 S1 P"1.io2.in"                                       ; configure active-low endstop for low end on Y via pin 1,io2.in
      M574 C0 Z0  		                           				 ; No C Z endstop
      M558 P8 C"!21.io0.in" H3 F150                                ; set Z probe type to unmodulated and the dive height + speeds
      G31  P500 X0 Y0 Z1.28                                        ; set Z probe trigger value, offset and trigger height
      M557 X0:800 Y0:800 S65                                       ; define mesh grid X/Y and probe spacing
      M308 S0 P"temp0" Y"thermistor" A"Bed" T100000 B3950           ; configure Bed sensor 1 as thermistor on pin temp0
      M950 H0 C"out0" T0                                            ; create bed heater output on out0 and map it to sensor 1
      M307 H0 R0.224 C219.6 D7.78 S1.00 V24.1                       ; PID auto tune results for Tool 1 bed heater
      M140 H0                                                       ; map heated bed to heater 1
      M143 H0 S120                                                  ; set temperature limit for heater 1 to 120C
      M308 S1 P"20.temp0" Y"pt1000" A"Tool 0"                       ; configure sensor 0 as thermistor on pin 20.temp0
      M950 H1 C"20.out0" T1                                         ; create nozzle heater output on 20.out0 and map it to sensor 0
      M307 H1 B0 R1.858 C109.4 D2.96 S1.00 V23.6                    ; PID auto tune results for Tool 0 Titan Aqua 1.75
      ;M308 S2 P"21.temp0" Y"pt1000" A"Tool 1"                       ; configure sensor 0 as thermistor on pin 20.temp0
      ;M950 H2 C"21.out0" T2                                         ; create nozzle heater output on 20.out0 and map it to sensor 0
      ;M307 H2 B0 R1.717 C105.7:98.6 D2.95 S1.00 V23.9               ; PID auto tune results for Tool 0 Titan Aqua 1.75
      ;fan
      M950 F0 C"out8" Q250        ; create fan 0 on pin out8 and set its frequency
      M106 P0 T115 S0.10 H1:2 C"Radiator Fan"                                                    ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"20.out2" Q250        ; create fan 1 on pin 20.out2 and set its frequency
      M106 P1 T205 S0.10 H1 C"Titan Aqua 1.75 T1 Hot end Fan"                                    ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"21.out2" Q250        ; create fan 2 on pin 21.out2 and set its frequency
      M106 P2 T205 S0.10 H2 C"Titan Aqua 1.75 T2 support material Fan"                           ; set fan 2 value. Thermostatic control is turned on
      M950 F3 C"out5" Q250        ; create fan 3 on pin out5 and set its frequency
      M563 P0 S"Titan Aqua 1.75" D0:2 H1 F0:1                         ; define tool 0
      M567 P0 E1.00:1.00                                              ; Mix drive E0 and drive E2
      G10  P0 X0 Y0 Z0                                                ; set tool 0 axis offsets
      G10  P0 R0 S0                                                   ; set initial tool 1 active and standby temperatures to 0C
      M563 P1 S"Titan Aqua 1.75 support" D1 H2 F0:2                   ; define tool 1
      G10  P1 X-15.4 Y0 Z0                                            ; set tool 2 axis offsets
      G10  P1 R0 S0                                                   ; set initial tool 1 active and standby temperatures to 0C
      T0 ; select first tool
        I think you may be experiencing this limitation
        The main board does not react to heater faults on expansion boards by pausing the print. This restriction is planned to be removed in firmware 3.4.
        https://duet3d.dozuki.com/Wiki/Duet_3_firmware_configuration_limitations#Section_Temporary_limitations
        aprzundefined 1 Reply Last reply Reply Quote 0
        • aprzundefined
          aprz @Phaedrux
          @phaedrux ok thanks for the help. I'll order a duet filament sensor to monitor filament issues for now until this is fixed.
