    PINDA leveling sensor
    2.7k
    • Gixxerfastundefined
      Gixxerfast @A Former User
      @thedragonlord The Caribou seems shorter. I have a Vinda here somewhere. I'll measure it. Un momento ...
      Nope, they are the same lenghth 35 mm. Same manufacturer Pepperl+Fuchs-Gruppe
      Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
      Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
      Ender 3 Pro with BTT SKR-2 + RRF
      • A Former User?
        A Former User @Gixxerfast
        @gixxerfast said in PINDA leveling sensor:
        excellent thanks I just need the lenght of the "cylinder"
        Gixxerfastundefined 1 Reply Last reply Reply Quote 0
          @thedragonlord See above. Same length 35 mm
          Gixxerfastundefined A Former User? 2 Replies Last reply Reply Quote 0
            Gixxerfast @Gixxerfast
            @gixxerfast Also I may warn that some report that they don't work reliably when enclosed in about 50C ambient near bed and hotend (Voron) but that's maybe a special use case IDK 🙂
            • A Former User?
              thanks
              • A Former User?
                uh... I'm designing the support to be as close as possibile to the Volcano heatblock... could be an issue? The printer isn't boxed and I usually print PETG so 240 nozzle and 75 the bed...
                  @thedragonlord said in PINDA leveling sensor:
                  Let's see if we can ping one opinion at least 🙂 @oc_geek What's your thought of the Vinda close to the hotend, OK?
                  oc_geekundefined 1 Reply Last reply Reply Quote 0
                  • oc_geekundefined
                    oc_geek @Gixxerfast
                    From my short experience with that probe it needs a quite thermal environment for returning reliable reads (temp ~ constant) and i think it struggles above a certain temp too. In all honesty i stepped away from such a probe... and rather quickly
                    However i have Voron printer which has a closed / heated chamber and so on... so it might be different in your case.
                    Personally i do not like it and do not like the very short range of action either. I found alternatives based on microswitch (we call Klicky in Voron context) to be infinitely better...
