    PINDA leveling sensor
    2.7k
    • oliofundefined
      oliof @A Former User
      @thedragonlord If you're not using the paneldue, the paneldue header is right next to the probe header and offers 5V:
      • Gixxerfastundefined
        Gixxerfast
        Speaking of SuperPinda and Vinda. This is an alternative. Check the data sheet 🙂
        https://caribou3d.com/en/sensors/762-9796-caribou-superpinda-probe-sensor-for-3d-printers.html#/220-superpindacable-1m_duet_connector
        Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
        Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
        Ender 3 Pro with BTT SKR-2 + RRF
          A Former User @oliof
          @oliof said in PINDA leveling sensor:
          I use panel due
            A Former User @Gixxerfast
            @gixxerfast said in PINDA leveling sensor:
            https://caribou3d.com/en/sensors/762-9795-caribou-superpinda-probe-sensor-for-3d-printers.html#/219-superpindacable-1m_4_pin_molex_connector
            Are the dimensions the same than the Vinda's?
            Gixxerfastundefined 1 Reply Last reply Reply Quote 0
              Gixxerfast @A Former User
              @thedragonlord The Caribou seems shorter. I have a Vinda here somewhere. I'll measure it. Un momento ...
              Nope, they are the same lenghth 35 mm. Same manufacturer Pepperl+Fuchs-Gruppe
                excellent thanks I just need the lenght of the "cylinder"
                  @thedragonlord See above. Same length 35 mm
                  Gixxerfastundefined A Former User? 2 Replies Last reply Reply Quote 0
                    Gixxerfast @Gixxerfast
                    @gixxerfast Also I may warn that some report that they don't work reliably when enclosed in about 50C ambient near bed and hotend (Voron) but that's maybe a special use case IDK 🙂
                      thanks
                        uh... I'm designing the support to be as close as possibile to the Volcano heatblock... could be an issue? The printer isn't boxed and I usually print PETG so 240 nozzle and 75 the bed...
                          @thedragonlord said in PINDA leveling sensor:
                          Let's see if we can ping one opinion at least 🙂 @oc_geek What's your thought of the Vinda close to the hotend, OK?
                          oc_geekundefined 1 Reply Last reply Reply Quote 0
                          • oc_geekundefined
                            oc_geek @Gixxerfast
                            From my short experience with that probe it needs a quite thermal environment for returning reliable reads (temp ~ constant) and i think it struggles above a certain temp too. In all honesty i stepped away from such a probe... and rather quickly
                            However i have Voron printer which has a closed / heated chamber and so on... so it might be different in your case.
                            Personally i do not like it and do not like the very short range of action either. I found alternatives based on microswitch (we call Klicky in Voron context) to be infinitely better...
