    [3.4.0b7] Firmware update changes 1LC temp
    Beta Firmware
    13
    59
    5.2k
    • Alex.crundefined
      Alex.cr
      I hope I am not jumping the gun on this one...
      Updating to 3.4b7 caused an immediate temp drop at idle for my PT1000 on my 1LC. I was previously using 3.4b6 and didn't have any issues, temperatures between all of my thermistors and PT1000 in the extruder matched within 3-4 degrees at idle (I have the PT1000,3 thermistors, the MCU temp calibrated, and a DHT22).
      My system is a standalone 6HC+3HC+1LC. The only change between screenshots below is loading beta7 onto my 1LC. If I revert it's firmware back to beta 6 my temperature for T0 goes back to expected/nominal temps.
      Beta 6 on the 1LC
      Beta 7 on the 1LC
      Thoughts? I was expecting to have to retune the heater given the changes but I wouldn't think that would effect the idle temp reported.
      Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
      • Gixxerfastundefined
        Gixxerfast
        OK, as a comparison I have the mini5+ and a v1.1 1LC with a PT1000 and it's reading fine.
        Have you verified that you have a complete install of beta7 ?
        2021-12-17 08:42:46	m115 b121
        Duet TOOL1LC rev 1.1 or later firmware version 3.4.0beta7 (2021-12-16 12:25:01)
        2021-12-17 08:43:18	m115
        FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.4.0beta7 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2021-12-16 12:22:56
        Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
        Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
        Ender 3 Pro with BTT SKR-2 + RRF
        Alex.crundefined 1 Reply Last reply Reply Quote 0
          jay_s_uk @Alex.cr
          @alex-cr I am also getting this on one toolboard.
          3.4b6 reports the normal room temperature. 3.4b7 reports -4.6 degrees.
          going back to 3.4b6 on the toolboard fixes the issue
          • Alex.crundefined
            Alex.cr @Gixxerfast
            @gixxerfast
            Yup can confirm.
            12/17/2021, 6:36:06 PM	M115 B20
            @jay_s_uk
            Thanks for confirming.
            Gixxerfastundefined 1 Reply Last reply Reply Quote 0
              Gixxerfast @Alex.cr
              @alex-cr Do you have a thermistor or a pt1000 or something else?
              • Alex.crundefined
                Alex.cr @Gixxerfast
                @gixxerfast
                PT1000 in my extruder on the 1LC.
                There are two thermistors for my heat bed on the 6HC. There is also a thermistor as one of my chamber sensors on the 3HC. These were unaffected.
                  Gixxerfast @Alex.cr
                  @alex-cr So strange, I have a pt1000 as well. Wonder what this problem can be caused by.
                  • Alex.crundefined
                    Alex.cr @Gixxerfast
                    @gixxerfast
                    Not sure but I remember this happening during another beta. It may have been in the 3.3 beta series.
                    • Fumbleundefined
                      Fumble
                      I’m running one V1.0 toolboard and one V1.1, both with thermistors
                      M308 S2 P"020.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin 121.temp0
                      M308 S3 P"021.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 3 as thermistor on pin 121.temp0
                      On the upgrade to b7 from b6 the first toolboard immediately threw a fault saying the circuit was open circuit showing the temp as -273.1
                      M122 also claimed the board didn’t have an accelerometer
                      Reflashing that board to b6 it shows within a degree of the other board at room temp.
                      But still no accelerometer
                      IDEX CoreXY Duet3 SBC+6HC+1LC
                        Gixxerfast @Fumble
                        @fumble Just to clarify. When downgrading the toolboard to b6 you do so with the main board as well and vice versa?
                        dc42undefined Fumbleundefined 2 Replies Last reply Reply Quote 0
                          dc42 administrators @Gixxerfast
                          @Alex-cr @Fumble @Gixxerfast @jay_s_uk please can you try connecting the thermistor or PT1000 to temp1 on the tool board, change config.g appropriately, and see whether the problem persists. This will help me identify the cause.
                          Fumbleundefined Gixxerfastundefined Alex.crundefined PCRundefined 5 Replies Last reply Reply Quote 0
                          • Fumbleundefined
                            Fumble @dc42
                            @dc42 Yes same using temp1 reports 18.5 with b6 and open circuit with b7
                            • Fumbleundefined
                              Fumble @Gixxerfast
                              @gixxerfast Downgrading I only updated the one toolboard. While I realise it might not be able to collect data using different firmware versions, I would have expected M122 to detect it ok
                                Gixxerfast @dc42
                                @dc42 Oh, mine is working fine with the v1.1 toolboard with a generic pt1000 and b7. I'm just butting in because it's interesting as I have the same setup and it's working fine ...
                                • Fumbleundefined
                                  Fumble @dc42
                                  @dc42 I notice Alex-cr is running SBC+6HC+1LC as am I while Gixxerfast is Mini5
                                  • Alex.crundefined
                                    Alex.cr @dc42
                                    @dc42 said in [3.4.0b7] Firmware update changes 1LC temp:
                                    @dc42 I have confirmed that moving the PT1000 to temp1 did not resolve the issue. The problem persists.
                                    • Alex.crundefined
                                      Alex.cr @Alex.cr
                                      Additional issues are occurring now. Once I performed a new heater tuning on this extruder to test the new algorithm I cannot get the heater to turn on.
                                      The M303 completed correctly and I updated my M307 command in my config. Now when I use DWC, G10,M568, or M109/M104 commands the heater will just sit there and not heat.
                                      Sending an M105 command confirms that the temps were requested.
                                      If I send the appropriate M303 command the system will heat/tune and act correctly. Reuploading B6 to the 1LC restores the ability to use the heater.
                                      • leobgundefined
                                        leobg
                                        I can confirm the erratic temperature reading after upgrading to B7 with 1LC v1.1. SBC + 6HC + 1LC. Flashing back to B6 returns thermistor readings to normal. Slice Engineering Hight Temp thermistor (450C).
                                        • PCRundefined
                                          PCR @dc42
                                          @dc42 same here. Dyze 450€ thermistor temp0 on toolboard. Reports open circuit after upgrade
                                            dc42 administrators @PCR
                                            Thanks. Please can those of you with the problem try the following:
                                            1. Install the modified beta7 tool board firmware from https://www.dropbox.com/sh/5ubjszy9fmlvzwu/AAAeOMGP-Yi-Gn9LZwQoPfita?dl=0.
                                            2. Check that the temperature reading is still incorrect.
                                            3. Send M122 B# where # is the CAN address of the tool board.
                                            4. Send M308 S# where # is the sensor number of the thermistor or PT1000 on the tool board.
                                            5. Post the M122 and M308 responses here.
                                            Marshalundefined Fumbleundefined jay_s_ukundefined 3 Replies Last reply Reply Quote 0
