    [3.4.0b7] Firmware update changes 1LC temp
    Beta Firmware
    13
    59
    4.8k
    • Sergeundefined
      Serge @Serge
      • leobgundefined
        leobg
        I have upgraded back to b7, (sbc mode), but apt spit an error:
        Setting up reprapfirmware (3.4-b7-1) ...
        Unhandled exception. System.Collections.Generic.KeyNotFoundException: The given key '' was not present in the dictionary.
           at System.Collections.Generic.Dictionary`2.get_Item(TKey key)
           at DuetControlServer.Utility.Firmware.UpdateFirmwareRemotely() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Utility/Firmware.cs:line 425
           at DuetControlServer.Program.CheckForAnotherInstance() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Program.cs:line 349
           at DuetControlServer.Program.Main(String[] args) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Program.cs:line 100
           at DuetControlServer.Program.<Main>(String[] args)
        Aborted
        I'll appreciate if someone can throw some insight on what might be wrong with the SBC upgrade mode..
        Meanwhile I have manually updated the 6HC and 1LC firmwares (B7-1) from the thread here. Temperature reads normal for me again now. Will give the new firmware a try to see if anything else pops up
        edit: here is M121 B121 output:
        M122 B121
        Diagnostics for board 121:
        Duet TOOL1LC rev 1.1 or later firmware version 3.4.0beta7+1 (2021-12-22 18:45:45)
        Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
        All averaging filters OK
        Never used RAM 2152, free system stack 2762 words
        Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,115) CanAsync(notifyWait,0.0%,61) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,27) TMC(delaying,3.0%,57) MAIN(running,91.8%,351) IDLE(ready,0.0%,26) AIN(delaying,5.0%,142), total 100.0%
        Last reset 00:06:32 ago, cause: software
        Last software reset time unknown, reason: AssertionFailed, available RAM 3392, slot 1
        Software reset code 0x0120 ICSR 0x00000000 SP 0x2000415c Task  Freestk 129 bad marker
        Stack: 00000544 00022ffc 00019b65 20003134 00016cff 20003134 000163d1 20000ed0 00000000 00000001 00008275 200071c8 200071c8 200071e0 00000000 20000f50 00011647 000223b8 00022474 00021ac8 00019b05 200071c8 200071c8 20000f50 000083ed 200071d8 000009c7
        Driver 0: pos 0, 414.0 steps/mm,standstill, SG min 2, read errors 0, write errors 1, ifcnt 177, reads 64992, writes 13, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0
        Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
        Peak sync jitter 1/6, peak Rx sync delay 599, resyncs 0/1, no step interrupt scheduled
        VIN voltage: min 24.7, current 24.8, max 24.8
        MCU temperature: min 37.8C, current 37.9C, max 38.4C
        Last sensors broadcast 0x00000002 found 1 205 ticks ago, 0 ordering errs, loop time 0
        CAN messages queued 8154, send timeouts 0, received 3564, lost 0, free buffers 37, min 37, error reg 110000
        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
        Accelerometer: LIS3DH, status: 00
        I2C bus errors 0, naks 3, other errors 0
        === Filament sensors ===
        Interrupt 4 to 12us, poll 6 to 572us
        Driver 0: pos 36.21, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
        • Marshalundefined Marshal referenced this topic
        • rjenkinsgbundefined
          rjenkinsgb
          I was referred to this thread by Marshal.
          I have a similar problem with a PT1000 reading low at ambient temperature on an LC1 toolboard, after fitting a new E3D one to replace a thermistor.
          The PT1000 reads 1071 Ohms at ambient, which should be 18.4'C
          (My heating runs at 18'C so pretty close).
          The tool with the PT1000 shows around 8 - 10'C lower than the other two tools, at room temperature; presently its showing 10.5 while the other tools and bed are showing from 18 to 21'C.
          I have just loaded the beta7-1 toolboard firmware and power cycled the machine; no change.
          I have also run the temperature calibration, which made a slight adjustment according to the status, but did not have any noticeable effect on the ambient reading.
          25/12/2021, 08:54:03	M308 S1 L999
          Measured L correction for port "20.temp0" is 0
          25/12/2021, 08:51:56	M308 S1 H999
          Measured H correction for port "20.temp0" is -10
          M122 B20 result:
          25/12/2021, 09:04:07	M122 B20
          Diagnostics for board 20:
          Duet TOOL1LC rev 1.0 or earlier firmware version 3.4.0beta7+1 (2021-12-22 18:45:45)
          Never used RAM 3620, free system stack 2788 words
          Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.1%,103) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) TMC(notifyWait,3.0%,57) MAIN(running,91.9%,329) IDLE(ready,0.0%,40) AIN(delaying,5.0%,142), total 100.0%
          Last reset 00:23:27 ago, cause: power up
          Last software reset data not available
          Driver 0: pos 0, 409.0 steps/mm,standstill, SG min 0, read errors 0, write errors 0, ifcnt 12, reads 48493, writes 12, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0
          Peak sync jitter 0/5, peak Rx sync delay 215, resyncs 0/0, no step interrupt scheduled
          VIN voltage: min 23.8, current 23.8, max 23.9
          MCU temperature: min 23.4C, current 27.7C, max 27.8C
          Last sensors broadcast 0x00000002 found 1 17 ticks ago, 0 ordering errs, loop time 0
          CAN messages queued 27894, send timeouts 0, received 23664, lost 0, free buffers 37, min 37, error reg 0
          Accelerometer: none
          I2C bus errors 4509, naks 4509, other errors 4509
          M308 S1 result
          25/12/2021, 09:05:33	M308 S1
          Sensor 1 (T0) type PT1000 using pin 20.temp0, reading 10.4, last error: sensor open circuit, R:2200.0 L:0 H:-10
          Hope this is useful?
          If there are any other tests I can do, please let me know.
          Original thread here:
          https://forum.duet3d.com/topic/26521/temperature-wrong-after-fitting-pt1000
          Robert J.
          Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
          Sergeundefined dc42undefined 2 Replies Last reply Reply Quote 0
          • PCRundefined
            PCR @dc42
            @dc42 i just build a new printer with the dyze 500 C thermistor. I am using the 3.4 B6 on toolboard and duet mini. But the temp of the thermistor is always 15-20 degrees off. I testet it with an external K type thermometer. I see that there was the problem with B7 but could it affect the dyze at B6 too? I am now on holiday but back soon. Will flash 3.3 then ASAP and will compare.
            • Sergeundefined
              Serge @rjenkinsgb
              @rjenkinsgb Have you try the semi automatic calibration ?
              https://duet3d.dozuki.com/Wiki/Calibrating_thermistor_and_PT1000_readings
              rjenkinsgbundefined 1 Reply Last reply Reply Quote 1
                rjenkinsgb @Serge
                @serge said in [3.4.0b7] Firmware update changes 1LC temp:
                Yep, I mentioned I had done that and the output from it was the first insert above.
                Robert J.
                  dc42 administrators @rjenkinsgb
                  @rjenkinsgb said in [3.4.0b7] Firmware update changes 1LC temp:
                  Do you mean beta7+1 ?
                  If you are certain that your PT1000 is reading correctly (which depends on how accurate your multimeter is), you can adjust the M308 L parameter manually to correct the PT1000 reading at low temperatures.
                  rjenkinsgbundefined oozeBotundefined Alex.crundefined 3 Replies Last reply Reply Quote 0
                    rjenkinsgb @dc42
                    @dc42 said in [3.4.0b7] Firmware update changes 1LC temp:
                    Yes, that's the version; I was not paying attention - though I should have seen it in the M122 output...
                    OK on the M308 - but what's the likelihood of it being significantly off at working temperatures?
                    I do trust the meter, it's a calibrated Fluke 187.
                    Robert J.
                    • oozeBotundefined
                      oozeBot @dc42
                      @dc42 I'll add to the mystery as I just updated 3 machines - all in SBC mode with a 6hc and a toolboard.
                      The first is an older machine with a Slice thermistor on temp0 (and temp1 is not utilized). It reported "Heater 1 fault: failed to read sensor: sensor open circuit" after upgrading to 3.4b7. Manually upgrading the toolboard to 3.4b7+1 resolved the issue and the temp reported by toolboard temp0 is equal 3.4b6.
                      The second machine is using a Slice PT1000 on temp0 and a thermistor on temp1. After upgrading to 3.4b7, both temps remained equal to 3.4b6. The temps remained the same after upgrading to 3.4b7+1.
                      The third machine is identical to the second machine - the only difference is the Raspberry Pi image has been upgraded to Bullseye for testing. After upgrading to 3.4b7, temp0 rapidly fluctuated between 9-15c (where it should read ~22c). Temp1also rapidly fluctuated between 18-22c (where it should read ~25c). Manually upgrading to 3.4b7+1 resolved the issue for both temp0 and temp1.
                      • Alex.crundefined
                        Alex.cr @dc42
                        To add another data point. Similar to my original post. I went ahead and updated to beta 7+2 to see if it fixed a heating issue on my 1LC and the temp dropped to about 4C at ambient again. Switching bat to 7+1 reverts the temp to normal(18C) ambient values.
                        Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
                          dc42 administrators @Alex.cr
                          @alex-cr thanks for that. Something strange is happening, possibly related to the alignment of a particular piece of code that reads the ADC. Unfortunately all the tool boards I have here don't show any difference between firmware versions, so I can't reproduce this.
                          PCRundefined 1 Reply Last reply Reply Quote 0
                          • PCRundefined
                            PCR @dc42
                            @dc42 have you tried it with the HT thermistors?
                            Best
                              rjenkinsgb
                              I've cheated with my PT1000:
                              I now have it set as a thermistor, so I can adjust the parameters.
                              This appears to work, though I've not tried a print with that tool again yet:
                              M308 S1 P"20.temp0" Y"thermistor" A"T0" T1070 B-416
                              Robert J.
                                @alex-cr and anyone else getting incorrect readings using 3.4.0beta7+2, please post a M122 B# report where # is the tool board number.
                                leobgundefined 1 Reply Last reply Reply Quote 0
                                  dc42 administrators @PCR
                                  @pcr said in [3.4.0b7] Firmware update changes 1LC temp:
                                  I've tried to day using a 470K resistor, to simulate a high temperature thermistor. I get the same range of readings (fluctuating over a range of about 1.5C) using RRF 3.4b6, 3.4b7, 3.4b7+1 and 3.4b7+2.
                                  Alex.crundefined 1 Reply Last reply Reply Quote 0
                                  • Alex.crundefined
                                    Alex.cr @dc42
                                    As requested!
                                    m122 b20
                                    Duet TOOL1LC rev 1.1 or later firmware version 3.4.0beta7+2 (2021-12-30 22:07:52)
                                    Never used RAM 2552, free system stack 2788 words
                                    Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,111) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(delaying,3.0%,57) MAIN(running,91.9%,351) IDLE(ready,0.0%,26) AIN(delaying,4.9%,142), total 100.0%
                                    Last reset 00:02:00 ago, cause: power up
                                    Last software reset time unknown, reason: AssertionFailed, available RAM 3392, slot 0
                                    Driver 0: pos 0, 406.0 steps/mm,standstill, SG min 0, read errors 0, write errors 0, ifcnt 12, reads 60259, writes 12, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0
                                    Peak sync jitter 5/9, peak Rx sync delay 204, resyncs 0/0, no step interrupt scheduled
                                    VIN voltage: min 24.2, current 24.3, max 24.3
                                    MCU temperature: min 37.4C, current 37.4C, max 38.0C
                                    Last sensors broadcast 0x00000004 found 1 77 ticks ago, 0 ordering errs, loop time 0
                                    CAN messages queued 2427, send timeouts 0, received 1575, lost 0, free buffers 37, min 37, error reg 0
                                    • leobgundefined
                                      leobg @dc42
                                      Latest I found reference is 7+1, where is 7+2 linked? Another threat? What changed between +1 and +2 btw?
                                      • Alex.crundefined
                                        Alex.cr @leobg
                                        @leobg
                                        Linked in a different thread, copied here for your convivence:
                                        @dc42 said in Expansion boards not working on 3.4b7?:
                                        @theolodian please try the files at https://www.dropbox.com/sh/cx760ysonlzzkjd/AACfsVfX4olHipuqmbWut5EKa?dl=0. If the problem persists, please power the system off for several seconds and then on again, wait for startup to complete, and post the result of sending M409 K"boards" again.
                                          @alex-cr thanks, the "All averaging filters OK" was what I wanted to see, to eliminate a possible cause.
                                          • Fumbleundefined Fumble referenced this topic
