Included files on duet 3 mini 5+?
Hi, I know this might be a bit of a stretch, but I managed to accidentally delete the startup test macro on the included sd card, so the printer will no longer respond. Does anyone have the files that are on the sd card that would reinstall this?
Thanks in advance,
Zac -
How much of the SD card was deleted? Any testing macros that came on the card shouldn't be used anyway since they were from the factory setup.
You can see the file structure for the SD card here
https://duet3d.dozuki.com/Wiki/SD_Card#Section_Creating_the_file_structure
@phaedrux It was only the macro called something along the lines of testing_startup, without it my printer won't seem to move or respond in any way, not even the fan which i configured to always be on will run. I have had a look at the page, but cannot find the exact file needed, maybe I need to rewrite a macro for it? . Thanks for the help
Has your config.g file been deleted?
That would cause the printer not to work much at all. -
@alankilian I don't think so, I'll check in a bit but need to go for about 2 hours, will get back in a bit
@zommy5re IIRC All it does is enabling the wifi I think so you can as well create a config.g file in the sys folder and add something like:
M550 P"myPrinter" ; set printer name
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP (for DWC)
M586 P1 S0 ; disableFTP (for remote backups)
M586 P2 S0 ; disable Telnet
