    InputShaping-Plugin-0.2.0-pre8-2 released
    Plugins for DWC and DSF
    12
    24
    2.1k
    • A Former User?
      A Former User @SIam
      This post is deleted!
      • oliofundefined oliof referenced this topic
      • MLoeweundefined
        MLoewe
        Hi, have connected a LIS3DH.
        The data could manually obtained without problems and used with accelerometer plugin.
        If i want to use the input shaping plugin, i can't select anything as "board address".
        Does the plugin only works with can bus modules?
        I'm using a Duet2Wifi with v3.4 and the 0.2.0-pre8 plugin from jay_s_uk
        • oozeBotundefined
          oozeBot
          When will a working version for 3.4 stable be released? We are receiving the below error both when installing and uninstalling and even through the plugin says it starts, it is in a stopped state after refreshing DWC.
          Thanks
          Failed to uninstall plugin
          InternalServerException in UninstallPlugin: ArgumentException in UninstallPlugin: Failed to get file info (error 22)
          • GeneRisiundefined
            GeneRisi @mfs12
            @mfs12 I was able to install the plugin, but when starting it up, I get a red popup message; "Failed to start plugin. TypeError: m[y] is undefined"
