    InputShaping-Plugin-0.2.0-pre8-2 released
    Plugins for DWC and DSF
    12
    24
    2.1k
    • ctilley79undefined
      ctilley79 @jay_s_uk
      @jay_s_uk Unless my mac is not zipping up the files correctly then I'm at a loss
      • Diamondbackundefined
        Diamondback
        Mine doesn't work either after changing just the version.
        SIamundefined 1 Reply Last reply Reply Quote 0
        • SIamundefined
          SIam @Diamondback
          I think we have to wait for the next version ....
          Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
          Duet WiFi 1.02 or later + DueX5
          RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
          Duet WiFi Server: 1.26
          Duet Web Control 3.4.0beta4 (2021-09-27)
          ctilley79undefined A Former User? 2 Replies Last reply Reply Quote 2
            ctilley79 @SIam
            @siam Hey. At least you got it to install
              jay_s_uk @ctilley79
              @ctilley79 InputShaping-0.2.0-pre8.txt
              rename it to .zip
              ctilley79undefined 1 Reply Last reply Reply Quote 0
                ctilley79 @jay_s_uk
                @jay_s_uk Nice way to get past the censors lol. Just out of curiosity, what process did you follow to fix the package?
                  jay_s_uk @ctilley79
                  @ctilley79 had to rebuild this one in the end due to DWC changes
                    A Former User @SIam
                    This post is deleted!
                    • oliofundefined oliof referenced this topic
                    • MLoeweundefined
                      MLoewe
                      Hi, have connected a LIS3DH.
                      The data could manually obtained without problems and used with accelerometer plugin.
                      If i want to use the input shaping plugin, i can't select anything as "board address".
                      Does the plugin only works with can bus modules?
                      I'm using a Duet2Wifi with v3.4 and the 0.2.0-pre8 plugin from jay_s_uk
                      • oozeBotundefined
                        oozeBot
                        When will a working version for 3.4 stable be released? We are receiving the below error both when installing and uninstalling and even through the plugin says it starts, it is in a stopped state after refreshing DWC.
                        Thanks
                        Failed to uninstall plugin
                        InternalServerException in UninstallPlugin: ArgumentException in UninstallPlugin: Failed to get file info (error 22)
                        • GeneRisiundefined
                          GeneRisi @mfs12
                          @mfs12 I was able to install the plugin, but when starting it up, I get a red popup message; "Failed to start plugin. TypeError: m[y] is undefined"
