Unsolved I think I found a bug
My printer is a delta printer
Board: Duet 2 Ethernet (2Ethernet)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta7 (2021-12-16)I have to run M999 after startup. If I don't do that I get errors, and the head won't move.
23/12/2021 23:02:49 G28
23/12/2021 23:02:38 Connection established
23/12/2021 23:02:31 Connection interrupted, attempting to reconnect...
HTTP request timed out
23/12/2021 23:02:22 M999
23/12/2021 23:02:14 Error: G0/G1: insufficient axes homed
23/12/2021 23:02:13 Warning: Driver 1 warning: phase A may be disconnected, phase B may be disconnected
Warning: Driver 2 warning: phase A may be disconnected, phase B may be disconnected
Warning: Driver 0 warning: phase A may be disconnected, phase B may be disconnected
23/12/2021 23:01:45 G28
Warning: Driver 0 warning: phase A may be disconnected, phase B may be disconnectedSteve
@rks7204 said in I think I found a bug:
Are you certain your motors don't have a bad crimp?
Can you send M122 and M98 P"config.g" and post the results?
Can you also share your config.g and homedelta.g? -
After sending M999 all motors are moving. If I don't send M999 I get the "disconnected" error. I believe that if it is a bad crimp, sending M999 wouldn't solve it.
23/12/2021 23:14:33 M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta7 (2021-12-16 12:22:11) running on Duet Ethernet 1.02 or later
Board ID: 08DGM-95BNL-MGPSN-6JKFJ-3S86L-12XRX
Used output buffers: 3 of 24 (19 max)
Static ram: 23804
Dynamic ram: 68812 of which 0 recycled
Never used RAM 19344, free system stack 136 words
Tasks: NETWORK(ready,26.3%,230) HEAT(notifyWait,0.0%,330) Move(notifyWait,0.0%,305) MAIN(running,73.6%,440) IDLE(ready,0.1%,30), total 100.0%
Owned mutexes:
Last reset 00:12:10 ago, cause: software
Last software reset at 2021-12-23 23:02, reason: User, GCodes spinning, available RAM 19320, slot 1
Error status: 0x00
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 22.6, current 24.9, max 25.2
Supply voltage: min 24.2, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
Events: 0 queued, 0 completed
Driver 0: pos 81255, standstill, SG min 0
Driver 1: pos 80409, standstill, SG min 15
Driver 2: pos 80836, standstill, SG min 49
Driver 3: pos 0, standstill, SG min n/a
Driver 4: pos 0, standstill, SG min n/a
Driver 5: pos 0
Driver 6: pos 0
Driver 7: pos 0
Driver 8: pos 0
Driver 9: pos 0
Driver 10: pos 0
Driver 11: pos 0
Date/time: 2021-12-23 23:14:31
Slowest loop: 13.25ms; fastest: 0.17ms
=== Storage ===
Free file entries: 10
SD card longest read time 1.0ms, write time 0.0ms, max retries 0
DMs created 83, segments created 5, maxWait 22861ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 5, completed 5, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
=== AuxDDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty
=== Network ===
Slowest loop: 17.56ms; fastest: 0.02ms
HTTP sessions: 1 of 8
Interface state active, link 100Mbps full duplexTripodMaker
Status
Idle
Mode: FFF
Tool Position
X
0.0
Y
0.0
Z
500.60
Extruder Drives
Drive 0
0.0
Speeds
Requested Speed
0 mm/s
Top Speed
0 mm/s
Sensors
Vin
24.4 V
MCU Temperature
24.8 °C
Z-Probe
542
Tools
Extra
Control Heaters
Tool Heater Current Active Standby Tool 0
T0 - Load Filament Heater 1
active 18.5 °CBed Heater 0
off 18.1 °CTemperature Chart
23/12/2021 23:15:50 M98 P"config.g"
HTTP is enabled on port 80
FTP is enabled on port 21
TELNET is disabledConfig.g :
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Dec 21 2021 21:14:01 GMT+0100 (Midden-Europese standaardtijd); General preferences
M550 P"TripodMaker" ; set printer name
M665 R167.220 L350.3926 B160 H505.578 X0.345 Y0.210 Z0; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0.38 Y-0.02 Z-0.36 ; Put your endstop adjustments here, or let auto calibration find them; Network
M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M92 X100.00 Y100.00 Z100.00 E166.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop; Z-Probe
M558 P1 C"!zprobe.in" H5 F120 T6000 R1 A5 X0 Y0 Z0 ; set Z probe type to unmodulated and the dive height + speeds
G31 P800 X0 Y0 Z-0.1 ; set Z probe trigger value, offset and trigger height
M557 R145 S20 ; define mesh grid; Heaters
M307 H0 R0.228 K0.256:0.000 D3.08 E1.35 S1.00 B0 ; enable PID mode for the bed heater and set PWM limit
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M950 F0 C"fan0" Q250 ; create fan 0 on pin fan0 and set its frequency
M950 F1 C"fan1" Q250 ; create fan 1 on pin fan1 and set its frequency
;M950 F2 C"fan2" Q250 ; create fan 2 on pin fan2 and set its frequency
;M106 P2 S2 H100:101:102 T44:65 L0.3 ; set fan 2 value. Thermostatic control is turned on
M308 S2 Y"drivers" A"DRIVERS" ; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
M308 S3 Y"mcu-temp" A"MCU" ; configure sensor 3 as on-chip MCU temperature sensor
M950 F2 C"fan2" Q100 ; create fan 2 on pin fan2 and set its frequency
M106 P2 H2:3 L0.15 X1 B0.3 T40:70 ; set fan 2 value; Tools
G10 P0 X9 Y0 Z0 ; set tool 0 axis offsets
T0 S0 ; select first tool
M912 P0 S3.2 ; calibrate MCU tempHomeDelta.g :
; homedelta.g
; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Dec 21 2021 22:18:44 GMT+0100 (Midden-Europese standaardtijd)
G91 ; relative positioning
G1 H1 X805 Y805 Z805 F1800 ; move all towers to the high end stopping at the endstops (first pass)
G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
G90 ; absolute positioning
G1 X0 Y0 F6000 ; move X+Y to the centreSteve
Ok so you're resetting the printer and getting these errors. I think that's actually normal. Or am I not understanding again?
@phaedrux
When i power on the printer. Ik get these errors. And the motors don't move. After I reset the printer with M999 the errors are gone. I can start printing.Steve
Out of curiosity, what happens if you add
G4 S5
(a five second delay) near the top of your config, between the general and network sections?
OK. Is the 24V (or 12v) power permanently on, or controlled somehow by the Duet board?
@rjenkinsgb
The power is not controlled by the duet bord.
I use a physical switch on the printer.
When the printer is off, there is no power suplied to the board.Steve
@rks7204 looks like a similar issue here.
https://forum.duet3d.com/topic/26261/3-4-0beta6-home-limit-switch-bugIt happened to me on the new 3.4 firmware as well. But only if I set acceleration to a high value (>8000-10000mm/min)
Funny is, this number works on 3.3 without Phase disconnected warning. -
My accelerations (as listed above) are not even near those high numbers.
undefined Phaedrux marked this topic as a question
