    Kossel XL Plus for Christmas!
    My Duet controlled machine
    656
    • rjenkinsgbundefined
      rjenkinsgb
      My new "Early christmas present" (as a kit & pile of parts) Kossel XL+:
      It's built from a surplus Think3dPrint3d frame kit with a Duet3 6HC to control it. It uses a Smart Effector and a Flex3drive, plus some printed fan mount parts I found on Thingiverse.
      The overall combination is superb, I'm really happy with the results!
      I finished setting it up and did the first real prints in the last couple of days, though I still need to tidy up some cables etc., and make a reel holder.
      Robert J.
      Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
        dc42 administrators @rjenkinsgb
        @rjenkinsgb I'm glad you like it! My large Kossel on which the T3P3 design was based is still my go-to printer.
        rjenkinsgbundefined JuJuDeltaundefined 2 Replies Last reply Reply Quote 0
          rjenkinsgb @dc42
          I found your "Precision Kossel" build blog when researching the kit before buying it.
          I thought it looked to be your design, and I used your parts list for the motors types etc. to complete it.
          The only real differences functionally are the Flex3drive extruder that came with it, and using a 6HC rather than the Duet 2WiFi.
          What speeds and accelerations etc. do you use on yours?
          Robert J.
          • JuJuDeltaundefined
            JuJuDelta @dc42
            The flex3drive hobbed gear is difficult to clean as it requires a strip down of the housing. Also the housing has split and delaminated.
            Any more problems and it will be replaced with something else.
            Not sure if upgraded/improved parts are available.
            I once left it unused for some months and the OEM toothed belts became deformed at the pulleys - I now park it in differing places!
            Friction prevents z creep.
            Otherwise it’s a great machine.
            T3DP3D Kossel XL+, Duet2Wifi, PanelDue 7i, RRF V3.2, Fl3xdrive, SmartEffector, Berd Air annulus, Cura 4.x, PrusaSlicer, RPi WiFi Camera, Heated Chamber
            rjenkinsgbundefined 1 Reply Last reply Reply Quote 0
              rjenkinsgb @JuJuDelta
              @jujudelta said in Kossel XL Plus for Christmas!:
              I had a problem with the drive cable outer not seating very far in to the top clamp and working loose; after refitting it a few times the top section split away from its flange. It's now got a "splint" made of cable ties between the body and drive outer to stop it flexing so much, plus a superglue repair to the top.
              However all the extruder .stl and CAD files are downloadable from the flex3drive site, so I don't see a problem with making a new top from stronger material, possibly a bit taller and with more bracing.
              Robert J.
                @rjenkinsgb said in Kossel XL Plus for Christmas!:
                M201 X3000 Y3000 Z3000 E1000		; Accelerations (mm/s^2)
                M203 X15000 Y15000 Z15000 E3600		; Maximum speeds (mm/min)
                M566 X600 Y600 Z600 E600		; Maximum instant speed changes
                M558 P8 C"zprobe.in+zprobe.mod" H3 F1000 T12000 R0.15 S0.02 A5
                I haven't tried to optimise these for speed.
                  rjenkinsgb @dc42
                  Thanks for that; the settings I'm using from the configurator are pretty close already, as it turns out, so I'll not mess it up!
                  Robert J.
                  • rjenkinsgbundefined rjenkinsgb referenced this topic
                  • UnderDoneSushiundefined
                    UnderDoneSushi
                    Looks awesome!
