    duet 3 mini 5+ input/output pins
    • Mentaluproarundefined
      Mentaluproar
      I want to put my BL touch on IO_1. Can I use the in and out pins on that one connector at the same time or only one of them, meaning the in pun would be moved to IO_4?
      I'm not entirely sure if I and O pins on this connector are sharing a pin on the MCU or not.
      Nurgelrotundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • Nurgelrotundefined
        Nurgelrot @Mentaluproar
        @mentaluproar Just wire it like Step 20 here: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+3+Mini+5++Guide+Part+1:+Wiring/87
        IO_1 should be fine.Don't worry about the picture saying anything about IO_4 if you see the note on that page it just an example and really has nothing to do with IO_4 (and you can't use IO_4 for a BLTouch anyway also explained in the notes for step 20)
          dc42 administrators @Mentaluproar
          @mentaluproar the input and output are separate MCU pins. You can use a single port as described at https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Duet_Num_3.
