BLTouch3 + Duet2 + RRPF3 Upgrade (not working properly)
I have found lots of posts on this and cannot seem to get my BL up and running after upgrading to the new board/firmware.
- I have checked all the wires many times - same setup on rrpf
- BL cycles as normal on startup with a solid light at the end
- Z Home raises the bed but never deploys the pin on BL
- Can't manually deploy or retract the pin and z-probe on UI says 1000 and is red.
I have to be missing something here with the new syntax - it was all just working before the upgrade. I do have to do a wire continuity test but hopefully it is just an issue with the new config.
Here is my config:
; Communication and general M111 S0 ; Debug off M550 PBigBot ; Machine name (P + anything you like) M551 Preprap ; Machine password (used for FTP connections) M552 S1 ; Enable WiFi M555 P2 ; Set output to look like Marlin M575 P1 B57600 S1 ; Comms parameters for PanelDue M669 k1 ; set CoreXY mode ; Configuration M569 P0 S0 ; X Drive 0 goes forwards (change to S0 to reverse it) M569 P1 S1 ; Y Drive 1 goes forwards. M569 P2 S1 ; ZaZb - Motors - Forwards M569 P3 S1 ; E0 Drive 3 goes forwards 0 M569 P4 S1 ; E1 Drive 4 goes forwards M350 X16 Y16 Z16 E16 I1 ; Set 16x microstepping with interpolation M92 X100 Y100 Z397 ; Set axis steps/mm. M92 E415 ; Set extruder steps/mm. M906 X800 Y800 Z800 E800 ; Set motor currents (mA). M201 X1000 Y1000 Z500 E500 ; Accelerations (mm/s^2) M203 X12000 Y12000 Z1200 E800 ; Maximum speeds (mm/min) M566 X800 Y800 Z30 E600 ; Maximum jerk speeds mm/minute M208 X300 Y300 Z500 ; set axis maxima (adjust to suit your machine) M208 X0 Y0 Z0 S1 ; set axis minima (adjust to make X=0 and Y=0 the edges of the bed) G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Endstops M574 X1 S1 P"xstop" M574 Y2 S1 P"!^ystop" ; Z probe BLTouch M558 P9 C"^zprobe.in"H5 F200 T2000 G31 X39 Y50 Z1 P2.5 M557 X15:285 Y15:285 S25 ; Heaters & Temp Sensors M308 S0 P"bedtemp" Y"thermistor" T100000 B4388 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4388 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 ; disable bang-bang mode for heater and set PWM limit ; Tools M563 P0 D0 H1 F0 ; define tool 0 ; Fans M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ;*** If you are using axis compensation, put the figures in the following command M556 S78 X0 Y0 Z0 ; Axis compensation here M208 S1 Z0 ; set minimum Z M501 ; Load Config-Override.g that is created using M500 T0 ; select first hot end ; M98 P/sys/homeall.g
Home Z (trying to get homez.g working and then I will update homeall.g)
G91 ; relative positioning G1 H2 Z5 F4800 ; lift Z relative to current position G90 ; absolute positioning G1 X150 Y105 F4800 ; go to first probe point G30 ; home Z by probing the bed```
deployprobe.g:
M280 P0 S10
retract.g:
M280 P0 S90
@interwebsdesigner said in BLTouch3 + Duet2 + RRPF3 Upgrade (not working properly):
Looks like you're missing a space between the pin name and the H5.
Does sending M401 and M402 cause the pin to deploy and retract?
retract.g:
Are the actual files called deployprobe.g and retractprobe.g and are they located in the system files area?
If you send the M280 commands to deploy and retract does it work?
Can you also send M122 and M98 P"config.g" in the console and share the results?
@interwebsdesigner
The declaration of the servo channel is missing.M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
As an example..
Insert that code before
M558
This post is deleted! -
@phaedrux said in BLTouch3 + Duet2 + RRPF3 Upgrade (not working properly):
M280
- Fixed the space
- They are named correctly in the system files area
- M280 commands are non responsive
M122
=== Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later Board ID: 0JD0M-9P6B2-NJ4S8-6J9D6-3SJ6S-1A4GJ Used output buffers: 3 of 24 (11 max) === RTOS === Static ram: 23460 Dynamic ram: 73244 of which 200 recycled Never used RAM 15176, free system stack 184 words Tasks: NETWORK(ready,186) HEAT(blocked,308) MAIN(running,449) IDLE(ready,20) Owned mutexes: === Platform === Last reset 00:03:02 ago, cause: software Last software reset at 2022-01-01 10:06, reason: User, GCodes spinning, available RAM 15352, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU temperature: min 20.8, current 25.0, max 25.2 Supply voltage: min 24.1, current 24.3, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: position 0, standstill, SG min/max not available Driver 1: position 0, standstill, SG min/max not available Driver 2: position 0, standstill, SG min/max not available Driver 3: position 0, standstill, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0 Driver 6: position 0 Driver 7: position 0 Driver 8: position 0 Driver 9: position 0 Driver 10: position 0 Driver 11: position 0 Date/time: 2022-01-01 10:09:34 Cache data hit count 221935625 Slowest loop: 6.06ms; fastest: 0.21ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 3.1ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 15.89ms; fastest: 0.00ms Responder states: HTTP(2) HTTP(1) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.26 WiFi MAC address 48:3f:da:a6:ef:04 WiFi Vcc 3.38, reset reason Power up WiFi flash size 2097152, free heap 23624 WiFi IP address 192.168.1.16 WiFi signal strength -52dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 2 0 0 0 0 0
M98 P"config.g"
M98 P"config.g" Heater 0 is disabled because its model is undefined Heater 1 is disabled because its model is undefined
I just haven't run the tuning yet
@DIY-O-Sphere
I added that line to the the config. New config here -; Communication and general M111 S0 ; Debug off M550 P"BigBot" ; Machine name (P + anything you like) M551 P"reprap" ; Machine password (used for FTP connections) M552 S1 ; Enable WiFi M555 P2 ; Set output to look like Marlin M575 P1 B57600 S1 ; Comms parameters for PanelDue M669 k1 ; set CoreXY mode ; Configuration M569 P0 S0 ; X Drive 0 goes forwards (change to S0 to reverse it) M569 P1 S1 ; Y Drive 1 goes forwards. M569 P2 S1 ; ZaZb - Motors - Forwards M569 P3 S1 ; E0 Drive 3 goes forwards 0 M569 P4 S1 ; E1 Drive 4 goes forwards M350 X16 Y16 Z16 E16 I1 ; Set 16x microstepping with interpolation M92 X100 Y100 Z397 ; Set axis steps/mm. M92 E415 ; Set extruder steps/mm. M906 X800 Y800 Z800 E800 ; Set motor currents (mA). M201 X1000 Y1000 Z500 E500 ; Accelerations (mm/s^2) M203 X12000 Y12000 Z1200 E800 ; Maximum speeds (mm/min) M566 X800 Y800 Z30 E600 ; Maximum jerk speeds mm/minute M208 X300 Y300 Z500 ; set axis maxima (adjust to suit your machine) M208 X0 Y0 Z0 S1 ; set axis minima (adjust to make X=0 and Y=0 the edges of the bed) G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Endstops M574 X1 S1 P"xstop" M574 Y2 S1 P"!^ystop" ; Z probe BLTouch M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H5 F200 T2000 G31 X39 Y50 Z1 P2.5 M557 X15:285 Y15:285 S25 ; Heaters & Temp Sensors M308 S0 P"bedtemp" Y"thermistor" T100000 B4388 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4388 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 ; disable bang-bang mode for heater and set PWM limit ; Tools M563 P0 D0 H1 F0 ; define tool 0 ; Fans M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ;*** If you are using axis compensation, put the figures in the following command M556 S78 X0 Y0 Z0 ; Axis compensation here M208 S1 Z0 ; set minimum Z M501 ; Load Config-Override.g that is created using M500 T0 ; select first hot end ; M98 P/sys/homeall.g
On power up it is still cycling the test and turning solid red. Just nothing with the M280 commands. I am going to go through the PDF and see if I missed anything.
@arnold_r_clark This did it. Works as expected now! Thanks all - on to the next problem
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
