    BLTouch w/ DUet 3 mini 5+ Wifi (Ender 3 Pro)
    IR Height Sensor
    2.0k
    • teachmedavis747undefined
      teachmedavis747
      I need some help. I feel like I've read every forum post in reference to this issue and still have yet to be able to solve my problem.
      I'm using my old Ender 3 Pro and I'm trying to set it up on a Duet 3 Mini 5+ (Wifi) but cannot get the BLTouch to work properly. I've been through the RepRap Config Tool and even used the config.json from this link to see if it would solve my problem. (https://s-ln.in/wiring-ender-3-to-duet-3-mini-wifi/). No luck. I still get the error message: "Z probe already triggered at start of move error". I'll post my config below for review. I have also followed all the info on this link but still cannot find a fix. I'm not sure if this may be the issue or not but I do NOT have the Z axis end stop/pin. I removed it from the Ender 3 years ago and would solely use the BLTouch. (https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Mini+5++Guide+Part+2:+Configuration/88)
      Can anyone help he here? It would be greatly appreciated as I've been trying to get this to work for several weeks without resolution. My current config.g is below:
      I am using the x and y axis end stop pins provided with the Ender 3 just to get it to work then I will tackle sensorless homing. Again, no Z axis end stop.
      ; generated by RepRapFirmware Configuration Tool v3.3.10
      M550 P"Prender" ; set printer name
      M918 P1 E4 F2000000 ; configure direct-connect display
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0.0 S0 ; physical drive 0.0 goes backwards
      M569 P0.1 S0 ; physical drive 0.1 goes backwards
      M569 P0.2 S1 ; physical drive 0.2 goes forwards
      M569 P0.3 S0 ; physical drive 0.3 goes backwards
      M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
      M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X235 Y235 Z235 S0 ; set axis maxima
      M574 X1 S1 P"io5.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io5.in
      M574 Y1 S1 P"io6.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io6.in
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P1 C"io3.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0
      M143 H0 S150 ; set temperature limit for heater 0 to 150C
      M308 S1 P"temp1" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
      M143 H1 S275 ; set temperature limit for heater 1 to 275C
      M950 F0 C"out5" Q500 ; create fan 0 on pin out5 and set its frequency
      M950 F1 C"out6" Q500 ; create fan 1 on pin out6 and set its frequency
      Gixxerfastundefined 1 Reply Last reply Reply Quote 0
      • Gixxerfastundefined
        Gixxerfast @teachmedavis747
        @teachmedavis747
        Hello
        First of all, ditch this row:
        Then add a M950 to define your servo pin (to something like in this example):
        M950 S0 C"io3.out" ; Duet 3 Mini 5+
        M558 P9 C"io3.in" H5 F300:120 A3 T6000               ; Duet 3 Mini 5+
        G31 P500 X37.1 Y9.25 Z4.370                   ; set Z probe trigger value, offset and trigger height
        Also in your M558 P1 C"io3.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
        Use P9 type instead.
        And see what happens. But take it easy, as you will probably have to change your homeall.g and your homez.g as well.
        Btw. Here you have a pretty good write-up of how to configure and connect the BLTouch
        https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
        Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
        Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
        Ender 3 Pro with BTT SKR-2 + RRF
        teachmedavis747undefined 1 Reply Last reply Reply Quote 0
          teachmedavis747 @Gixxerfast
          @gixxerfast
          Thanks for the fast response. Are these the changes you suggest I make?
          M558 P9 C"io3.in" H5 F120 T6000                    ; set Z probe type to
          Here are my current homez.g and homeall.g - I had read through that article before but did not want to make changes to the files that were produced from the RepRap Config Tool.
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sun Jan 02 2022 00:25:05 GMT-0700 (Mountain Standard Time)
          G1 H2 Z5 F6000          ; lift Z relative to current position
          G1 H1 X-240 Y-240 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X5 Y5 F6000       ; go back a few mm
          G1 H1 X-240 Y-240 F240  ; move slowly to X and Y axis endstops once more (second pass)
          G1 X15 Y15 F6000        ; go to first bed probe point and home Z
          G30                     ; home Z by probing the bed
          ;G91                    ; relative positioning
          ;G1 Z5 F100             ; lift Z relative to current position
          ;G90                    ; absolute positioning
          ; homez.g
          ; called to home the Z axis
          G1 X15 Y15 F6000 ; go to first probe point
          Once again, thank you for your help!
            @teachmedavis747
            Yes for now anyway, You could move the M950 down to the Z-probe section as it's where it belongs right now. But that's only a detail.
            At a glance your homing scripts looks alright.
            You might want to set the x and y offset of the probe in the G31 (in z-probe section in config.g) since I assume that you don't have your probe at the same position as the nozzle 🙂
            But, you could start with that and see what happens. Only make sure that you have enough Z to start with so that the probe pin can deploy without touching the bed.
            Edit: As a note, you might want to in homeall.g and homez.g move to th emiddle of the bed (adjusted with the probe offset) before go probe (G30)
            Edit2: A stock position for BLTouch x and y a ENder3 is usually here:
            G31 P500 X-40 Y-12 Z2.5
            Edit3: Here
            s a cool thing I found from Team Gloomy's config example. In your homez.g and homeall.g when you move to probe (G30) and you want to do it in th emiddle of the bed this is really cool 🙂 (Note, it's all one line)
            G1 X{(move.axes[0].max/2)+abs(sensors.probes[0].offsets[0])} Y{(move.axes[1].max/2)+abs(sensors.probes[0].offsets[1])} F10000
            Here's the rest of the config example: https://github.com/TeamGloomy/ender-3-fly-E3/tree/bltouch
            teachmedavis747undefined 1 Reply Last reply Reply Quote 1
              @gixxerfast
              Very interesting. I copied their homeall.g and homez.g
              I tried the g30 command but the BLTouch did not deploy. i stopped it before it crashed into the bed. I also tried to home XY but for some reason the pins are not being read. Any ideas on these issues?
                @teachmedavis747 OK, so:
                EDIT: Forgot: Do you have the deployprobe.g and the retractprobe.g in your /sys directory? How do they look ?
                EDIT2: Your endstop config is correct. But how have you connected them. It should be ground and in-pin? Move the bed to the endstop and the x-carriage also to the endstop and check status with M119
                1. Does the BLTouch glow red when the printer is on?
                2. WHen you start the printer does it deploy and stove the pin twice as a startup routine?
                Can you show how you have connected the probe wires ? Picture ?
                There are so many different colour variations of the wiring so do you remember how you had it connected with Marlin?
                  @gixxerfast
                  Yes, It glows red and deploys twice once powered on.
                  Here is a picture of the wiring:
                  Edit:
                  Here is deployprobe.g
                  M280 P0 S10
                  and retractprobe.g
                  M280 P0 S90
                  Edit 2: Here is the M119 with both x and y at the endstops:
                  Printer is now online.
                  >>> m119
                  SENDING:M119
                  Endstops - X: at min stop, Y: at min stop, Z: no endstop, Z probe: not stopped
                  Gixxerfastundefined 2 Replies Last reply Reply Quote 0
                    @teachmedavis747 Run:
                     M280 P0 S10
                    and see what happens. Then try
                     M280 P0 S90
                      @gixxerfast
                      Nothing happens when I send either deploy or retract
                        @teachmedavis747 said in BLTouch w/ DUet 3 mini 5+ Wifi (Ender 3 Pro):
                        Printer is now online. >>> m119 SENDING:M119 Endstops - X: at min stop, Y: at min stop, Z: no endstop, Z probe: not stopped
                        Yes, but that seems to work just fine 🙂
                          OK, this should work, Can you send a picture of the BLTouch where you can see the wires as they go into the probe just to make sure that the right wires goes to the correvt places. We know that 5v and ground is correct. But we should be able to deploy with the config that your have.
                          You have saved and restarted after the changes right?
                            @teachmedavis747 Also, please post your complete config.g again.
                            Just to make sure ...
                              @gixxerfast
                              Hi. I apologize for the delay. I was under the weather a few days. While I was down I ordered some new wires for the BLTouch. I installed them today and figured out that was my issue as far as deploying the probe. Fixed.
                              Question for you. When I hit "Home X"and "home y"... should the bed and X axis move towards the end stop pin? They do not make that move.
                                @teachmedavis747 That's great.
                                Yes, as long as you have a homex.g and a homey.g containing homing instruction in your /sys directory
                                  @gixxerfast
                                  Okay. I was able to get it to run G28. However, another issue. Maybe you can help me with this as well. I had to switch the direction of the x and y axis motors in config.g. (I replaced the x axis motor with a high torque motor from e3d).
                                  When I enter G28 the extruder travels in the wrong direction. Instead of going towards the pin, it travels the opposite direction. How can I fix the homing files to compensate for this change? I will attach my config.g and homeall
                                  Homeall
                                  ; homeall.g
                                  ; generated by RepRapFirmware Configuration Tool v3.1.10+4-LPC on Wed Jan 06 2021 14:08:16 GMT+0000 (Greenwich Mean Time)
                                  G1 H1 X-240 Y240 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                                  G1 H1 X-240 Y240 F360  ; move slowly to X and Y axis endstops once more (second pass)
                                  G90
                                  ; ################# Home Z Preparation ################
                                  M558 F250 				 										; Set the probing speed
                                  G30
                                  config.g
                                  ; Configuration file for Duet 3 Mini 5+ (firmware version 3)
                                  M558 P9 C"io3.in" H5 F120 T6000                    ; set Z probe type to unmodulated and the dive height + speeds
                                  G31 P500 X-19 Y-28 Z2.5                                ; set Z probe trigger value, offset and trigger height
                                  homex
                                  ; homex.g
                                  ; called to home the X axis
                                  G1 H1 X-240 F3000 ; move quickly to X axis endstop and stop there (first pass)
                                  G1 H2 X5 F6000    ; go back a few mm
                                  G1 H1 X-240 F240  ; move slowly to X axis endstop once more (second pass)
                                  G1 H2 Z-5 F6000   ; lower Z again
                                  homey
                                  ; homey.g
                                  ; called to home the Y axis
                                  G1 H1 Y240 F3000 ; move quickly to Y axis endstop and stop there (first pass)
                                  G1 H2 Y5 F6000    ; go back a few mm
                                  G1 H1 Y240 F240  ; move slowly to Y axis endstop once more (second pass)
                                  Phaedruxundefined Gixxerfastundefined 4 Replies Last reply Reply Quote 0
                                    Phaedrux Moderator @teachmedavis747
                                    There are 3 parts to this. The direction of motor rotation, the endstop position definition, and the movement direction in the homing macros.
                                    -x should move left, +x should move right
                                    -y should move to the front, +y should move to the back
                                    M569 is where the rotation direction is set
                                    M574 defines where the endstops are located. high end of travel (positive move to reach) or low end of travel (negative move to reach)
                                    The G1 H moves in the homing macros should move towards the endstop either positive or negative.
                                    If you require more guidance we'd need to at least know where your endstops are physically located to know if your config is correct.
                                      @teachmedavis747 Hmm, from the top of my head I know of no special homing or probe related changes needed to fix that. Are you sure your Z-motor doesn't need reversing as well?
                                      When you home x and y does z move in the right direction. Up and then down again?
                                        @gixxerfast Yes. Z-axis moves well.
                                          teachmedavis747 @Phaedrux
                                          @phaedrux Sure.
                                          On the ender 3 the x-axis endstop pin is located on the far left of the x-axis. The y-axis is located at the back of the printer next to the y-axis stepper motor. I believe I have it set at low end for both when I configured the file using the RepRap tool.
                                          So if I changed the direction in 569 for both the x and y-axis motors... what others changes would be needed to get it to g28 in the right direction?
                                            Just do be clear can you explain what you mean here exactly?
                                            Your homeall.g is not correct as it moves the y in the wrong direction. You should try to go to relative -(max bed size x + some more) and -(max bed size y + some more)
                                            Also, I would split that so I first home x, then y and lastly z.
                                            In my homeall.g I just call homex.g, homey.g and homez.g instead of repeating the commands again.
