    Wifi fails with "another SPI transfer pending"... 2 diff boards
    Using Duet Controllers
    975
    • abitseanundefined
      abitsean
      So this is a strange one. I have a Duet2 wifi that has been working great for a couple months.
      Go away for a couple weeks for work and when I get back, it isn't connected to my wifi network anymore. I go through the steps I followed to headlessly get it online and configured when I set it up about 6 months ago, only now I am getting a strange error about SPI that makes no sense to me and I can't seem to find any relevant info/solutions online.
      Please see below and (hopefully) tell me I'm an idiot and the culprit is something silly that I skimmed right over in all the different procedures (upgrade from web, sd card upgrades-a-plenty, firmware reflash with SAM-BA 2.17 which appears to succeed but apparently does not, access point mode... etc)
      Any assistance would be greatly appreciated because, at this point, I think I have attempted every procedure / suggestion that exists on the world-wide-information-super-interwebs, and my google-fu isn't 'weak' by any stretch but I have come up empty at the end of my journey.
      Thanks in advance
      m122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
      Board ID: **********************
      Used output buffers: 1 of 24 (12 max)
      Static ram: 23876
      Dynamic ram: 73544 of which 12 recycled
      Never used RAM 16984, free system stack 193 words
      Tasks: NETWORK(ready,7.5%,517) HEAT(delaying,0.0%,386) Move(notifyWait,0.1%,364) MAIN(running,92.4%,439) IDLE(ready,0.0%,29), total 100.0%
      Owned mutexes: USB(MAIN)
      Last reset 00:12:38 ago, cause: power up
      Last software reset at 2021-12-20 12:08, reason: User, GCodes spinning, available RAM 12208, slot 2
      Error status: 0x00
      Step timer max interval 0
      MCU temperature: min 18.8, current 19.2, max 19.7
      Supply voltage: min 1.7, current 1.8, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
      Driver 0: position 0, ok, SG min/max not available
      Driver 1: position 0, ok, SG min/max not available
      Driver 2: position 0, ok, SG min/max not available
      Driver 3: position 0, ok, SG min/max not available
      Driver 4: position 0, ok, SG min/max not available
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Slowest loop: 0.38ms; fastest: 0.13ms
      === Storage ===
      Free file entries: 10
      SD card 0 not detected, interface speed: 30.0MBytes/sec
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is ready with "m122" in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 0.19ms; fastest: 0.00ms
      HTTP sessions: 0 of 8
      • WiFi -
        Network state is disabled
        WiFi module is disabled
        Failed messages: pending 0, notready 2, noresp 0
        ok
      m587
      Failed to retrieve network list: WiFi module is disabled
      ok
      m552 s0
      ok
      m587
      Failed to retrieve network list: another SPI transfer is pending
      ok
      m587 S"ssid" P"password"
      Error: M587: Failed to add SSID to remembered list: another SPI transfer is pending
      ok
      m588 S"*"
      Error: M588: Failed to reset the WiFi module to factory settings: another SPI transfer is pending
      ok
      m552 S1
      Turn off the current WiFi mode before selecting a new one
      ok
      M552 S0
      ok
      M552 S1
      ok
      M552 S-1
      WiFi module stopped
      ok
      M552 S1
      ok
      M588 S"*"
      ok
      M589
      Error: M589: Failed to retrieve own SSID data: another SPI transfer is pending
      ok
      M589 S"ssid" P"passworddd" I2.2.2.2
      Error: M589: Failed to configure access point parameters: another SPI transfer is pending
      ok
      jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @abitsean
        @abitsean try flashing the wifi firmware again with M997 S1
          Ensure you have this wifi server bin file in the firmware folder before trying to reflash with M997 S1
          https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/DuetWiFiServer.bin
          • abitseanundefined
            abitsean
            I have tried 3 different cables (which I tested on a duet 3 and transferred a file to it just fine, so it's not a cable issue)
            I have also tried every combination of baud rate and flow control imaginable, all with the same result...
            M115<CR>
            Error: Bad command: [0x11]M115
            ok
            M115<CR>
            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-06-15 21:45:03
            ok
            M115
            ok
            M115
            ok
            M115
            ok
            M115
            ok
            M997 S1
            Trying to connect at 230400 baud: failed
            Trying to connect at 115200 baud: failed
            Trying to connect at 74880 baud: failed
            Trying to connect at 9600 baud: failed
            Error: Installation failed due to comm write error
            ok
              Phaedrux Moderator @abitsean
              @abitsean said in Wifi fails with "another SPI transfer pending"... 2 diff boards:
              Is your board being powered by VIN or just via USB?
              This speed seems oddly high for a Duet2. It should be 20MB/s
              Can you go through this guide and tell us what you find?
              https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
              https://docs.duet3d.com/User_manual/Troubleshooting/Duet_wont_respond
              Can you take some photos of the board in case we can spot a failed component?
              When and where did you purchase the Duet?
              MartinMVundefined 1 Reply Last reply Reply Quote 0
              • MartinMVundefined
                MartinMV @Phaedrux
                @Phaedrux
                Hit me with the 3.3 update too...
                same problem. just your linked website does not exist anymore.
                What shall I do?
                Phaedruxundefined oliofundefined 2 Replies Last reply Reply Quote 0
                  Phaedrux Moderator @MartinMV
                  @MartinMV sorry, which?
                  • oliofundefined
                    oliof @MartinMV
                    @MartinMV
                    a) probably best to keep to your own thread rather than re-opening three year old ones.
                    b) check the new docs site at https://docs.duet3d.com/en/User_manual/Troubleshooting/Duet_wont_respond
                    (Bonus tip, dont hit enter on the search bar there if you type search terms)
