    Usable Laser / 5V PWM Outputs on Expansion Board 1XD
    Laser Cutters
    • NeueKlasseundefined
      NeueKlasse
      I want to know if it is Possible to use for example io2_out on the Expansion Board 1XD
      together with M452
      Original Command:
      M452 C"out9" R255 F200
      Modified Command:
      (for CAN Address 40)
      M452 C"40.io2_out" R255 F200
      or is the Firmware not able to use it?
      at the moment i cannot test it because i wait for the 1XD Board.
      Prusa Mini, Chiron @ BMG X2
      Metal SLS Printer Development
      • Phaedruxundefined Phaedrux moved this topic from Duet Hardware and wiring
        dc42 administrators @NeueKlasse
        @neueklasse I'm sorry, it's not supported. The reason is that the code to control the laser power has to adjust it dynamically according the the instantaneous speed of the move.
        • o_lampeundefined
          o_lampe @dc42
          Would it help to implement PPI mode into the 1XD firmware? That way the stepper pulses of the motor would be the base for the power output and it wouldn't be speed related anymore.
            dc42 administrators @o_lampe
            @o_lampe RRF already uses PPI mode.
            It would be possible to support lasers connected to expansion boards, but quite a lot of work, so I am only likely to implement it if several users or an OEM need it.
