setting the temperature using 12864 mini
@dc42 it's a new issue.
@dc42 I can say with confidence that the problem with negative temperatures was on the stable release 3.3
@vladimir_u said in setting the temperature using 12864 mini:
What exactly is the problem?
@dc42 I'm sorry, maybe I'm translating some phrases incorrectly. English is not my native language. For me, "problem" and "issue" are words with the same meaning. In my understanding, negative temperature and negative flow value cannot be in the physical sense. And the ability to set these parameters from the printer screen seems unreasonable. Whether this is a problem or a issue I can't say for sure. I would say it's a trouble.
Does anything bad happen when you select a negative range?
@phaedrux No, nothing bad is happening
