error zoffset for bl touch and duet3 firmware 3.4 beta 7+1
duet 3 v1.01
24 volt
Hi I'm noticing the following inconsistency problem on BLTouch : when I start the new print the z offset does not remain costyante as per the setting done to the machine, I notice that sometimes the nozzle gets too close and triggers the extruder motor. when I reset the machine then resumes the right z offset, in short, from one print to the next z offset changes a little it seems that the firmware loads the modified values ...
Can you give us more info on your setup? Configs?
Have you tried the latest beta updates?
https://forum.duet3d.com/topic/26787/unofficial-rrf-3-4-0beta7-4-files/
; Configuration file for Duet 3 (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Dec 31 2021 12:22:58 GMT+0100 (Ora standard dell’Europa centrale); General preferences
M550 P"Duet 300X Dual" ; set printer name
M955 P0 C"spi.cs3+spi.cs2"
M669 K1 ; select CoreXY mode; Network
M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0.1 S1 ; physical drive 0.1 goes forwards
M569 P0.2 S0 ; physical drive 0.2 goes forwards
M569 P0.3 S0 ; physical drive 0.3 goes forwards
M569 P0.4 S0 ; physical drive 0.4 goes forwards
M584 X0.0 Y0.1 Z0.2 E0.3:0.4 ; set drive mapping
M350 X128 Y128 Z128 E128:128 I1 ; configure microstepping with interpolation
M92 X640.00 Y640.00 Z5120.00 E3367.10:3367.70.31 ; set steps per mm
M566 X800.00 Y800.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X12000.00 Y12000.00 Z500.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
M201 X2300.00 Y2300.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
M906 X900 Y900 Z1000 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout
M593 P"zvd" F70; Axis Limits
M208 X-18 Y-5 Z0 S1 ; set axis minima
M208 X305 Y305 Z260 S0 ; set axis maximaM671 X10:300:300:10 Y290:290:5:5 P0.5
M591 D0 P5 C"e0_stop" R40:120 E3.0 S0; Endstops
M574 X1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io1.in
M574 Y1 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io2.in
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
M558 P9 C"^io7.in" P9 H5 F500:100 T6000 A5 R0.1 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X12.5 Y-20 Z1.55 ; set Z probe trigger value, offset and trigger height
M557 X20:290 Y15:300 S25:20 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0
M950 H0 Q10 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0
M143 H0 S130 ; set temperature limit for heater 0 to 120C
M308 S1 P"temp1" Y"pt1000" ; configure sensor 1 as PT1000 on pin temp1
M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
M143 H1 S400 ; set temperature limit for heater 1 to 400C
M308 S2 P"temp2" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin temp2
M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2
M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H2 S280 ; set temperature limit for heater 2 to 280C; Fans
M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
M106 P0 S0 H1:2 T45 ; set fan 0 value. Thermostatic control is turned on
M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
M563 P0 D0 H1 F1 ; define tool 0
M563 P1 D1 H2 F1 ; define tool 0
G10 P1 X25 Y0 Z0 ; set tool 0 axis offsets
T0 ; select first tool
M150 X0 ; set LED type to NeoPixel and set SPI frequency to 3MHz
M150 B255 P128 S65 F0
M501 -
@massimilianoconti said in error zoffset for bl touch and duet3 firmware 3.4 beta 7+1:
Not sure if it will make a difference but you have P9 listed twice.
Can you post your homeall and homez?
Are you using mesh compensation or auto leveling?
What exactly does that mean?
Yes
use mesh compensation or automatic leveling
maybe it's not good P 9 repeated I don't know how it happened
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Jan 01 2022 15:36:30 GMT+0100 (Ora standard dell’Europa centrale)
G91 ; relative positioning
G1 H1 X-310 Y-310 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-310 ; home X axis
G1 H1 Y-310 ; home Y axis
G1 X5 Y5 F6000 ; go back a few mm
G1 H1 X-310 F360 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y-310 ; then move slowly to Y axis endstop
G90 ; absolute positioning
G1 X15 Y35 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioning -
When do you run G32 or load a mesh?
Post your bed.g and the slicer start gcode as well please.
Also test with the new 3.4 beta 7+4 updates. -
Ok thank you. meanwhile I removed the P 9. could you give me the link to download the firmware 3.4 beta 7+4?
Thank you
start script
G28 F4000;
M150 R255 U255 B255 P128 S65 F0M561 ; Clear any bed transform
G29 S1;G1 Z0.470 F7800.000
G1 X10 Y8 Z10 F3000
G1 Z0 F500T0
G92 E0G1 Z0.25 F400
G1 X80 Y8 E60 F100T1
G92 E0G1 X140 Y8 E60 F100
; bed.g
; generated by RepRapFirmware Configuration Tool v3.3.2 on Sun Sep 26 2021 01:04:15 GMT+0200 (Ora legale dell’Europa centrale)
G29 S2; Clear bed height map
; Probe 4-point
M401 ; Deploy probe - deployprobe.g
G30 P0 X10 Y290 Z-9999 ; Front Right
G30 P1 X300 Y290 Z-9999 ; Front Left
G30 P2 X300 Y5 Z-9999 ; Center Rear
G30 P3 X10 Y5 Z-9999 S4 ; Center Rear
M402 ; Retract Probe - retractprobe.g
M300 S715 P1500
G4 P1500
G29 S1 -
I did. https://forum.duet3d.com/topic/26787/unofficial-rrf-3-4-0beta7-4-files
When do you call G32 to do the leveling and loading of the mesh?
M402 ; Retract Probe - retractprobe.gThis is not needed with the BLtouch
Thank you. I think it will be uploaded. Printing is fine.anyway how do you see exactly if the mesh is loaded?
If you send M122 it will have a line for compensation in use. If it says mesh, it is active. If it says none, it is not.
M122
RepRapFirmware for Duet 3 MB6HC version 3.4.0beta7+1 (2021-12-22 16:03:36) running on Duet 3 MB6HC v1.01 or later (standalone mode)
Board ID: 08DJM-9P63L-DJMSS-6J9DD-3S46N-TVFH8
Used output buffers: 1 of 40 (23 max)
Static ram: 150664
Dynamic ram: 95148 of which 164 recycled
Never used RAM 100928, free system stack 130 words
Tasks: NETWORK(ready,24.0%,219) ETHERNET(notifyWait,0.1%,169) HEAT(notifyWait,0.0%,324) Move(notifyWait,1.5%,248) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,362) CanClock(delaying,0.0%,333) TMC(notifyWait,8.9%,58) MAIN(running,65.4%,925) IDLE(ready,0.0%,30), total 100.0%
Owned mutexes:
Last reset 00:24:15 ago, cause: software
Last software reset at 2022-01-13 22:50, reason: User, GCodes spinning, available RAM 104696, slot 0
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
Error status: 0x00
Aux0 errors 0,0,0
Step timer max interval 153
MCU temperature: min 43.9, current 46.7, max 46.9
Supply voltage: min 23.6, current 23.8, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/12/0, gc cycles 0
Events: 0 queued, 0 completed
Driver 0: pos 206422, ok, SG min 0, mspos 967, reads 52485, writes 17 timeouts 0
Driver 1: pos 7789, ok, SG min 0, mspos 571, reads 52485, writes 17 timeouts 0
Driver 2: pos 33670, ok, SG min 0, mspos 641, reads 52485, writes 17 timeouts 0
Driver 3: pos 0, ok, SG min 0, mspos 620, reads 52485, writes 17 timeouts 0
Driver 4: pos 0, standstill, SG min 0, mspos 1, reads 52486, writes 17 timeouts 0
Driver 5: pos 0, standstill, SG min 0, mspos 8, reads 52492, writes 11 timeouts 0
Date/time: 2022-01-13 23:15:16
Slowest loop: 32.87ms; fastest: 0.05ms
=== Storage ===
Free file entries: 9
SD card 0 detected, interface speed: 25.0MBytes/sec
SD card longest read time 2.7ms, write time 5.2ms, max retries 0
=== Move ===- list itemDMs created 125, segments created 38, maxWait 211955ms, bed compensation in use: mesh, comp offset 0.000
=== MainDDARing ===
Scheduled moves 16146, completed 16101, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
=== AuxDDARing ===
Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
Heater 0 is on, I-accum = 0.4
Heater 1 is on, I-accum = 0.2
Segments left: 1
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is doing "G1 X167.119 Y158.677 E0.0301" in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty
=== CAN ===
Messages queued 13102, received 0, lost 0, boc 0
Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49), ts 7276/0/0
Tx timeouts 0,6,7275,0,0,5818 last cancelled message type 30 dest 127
=== Network ===
Slowest loop: 39.85ms; fastest: 0.02ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
HTTP sessions: 1 of 8
- Ethernet -
State: active
Error counts: 0 0 1 0 0
Socket states: 5 2 2 2 2 0 0 0
Yes it is active
perfect. I tried to install version 3.4 beta 7+6 but in the end from an error drive 0
perfect. I tried to install I think it's the firmware that has something in the wrong installation. I put back the 3.4 beta 7 + 1 and it went immediately fine. version 3.4 beta 7+4 is not present among the downloaded files but only the 3.4 beta 7+6
@massimilianoconti the spurious error from driver 0 is fixed in the 3.4beta7+7 files now at https://www.dropbox.com/sh/i5vox3xmkd55gaz/AAC19mI0WEC5GmEjLOBRbKs-a?dl=0.
perfect thank you very much. now the version works in the installation. I do some tests and let you know
This post is deleted! -
Firmware 3.4 beta 7+7 solved the heater problem when starting a new print. the heater is fine part good also the bl touch seems to be fine. I do further tests and communicate news
