    SOLVED Error: M106: Fan number 3 not found
    • lildannyoso
      lildannyoso last edited by
      I am getting an Error : M106: Fan number 3 not found and the part cooling fans are not turning on. Below is the GCode for the fans, and I am not sure why the error is referencing fan 3 instead of fan1.
      M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
      Any help would be appreciated.
        Please post your full config.g
        The output of M122 would be useful as well.
        lildannyoso 2 Replies Last reply Reply Quote 0
        • deckingman
          deckingman @lildannyoso last edited by
          @lildannyoso In addition to what @Phaedrux has said, if you have not configured a fan 3, then you need to look at what might be calling for fan 3. When do you get the error? If it's when printing, then the problem might be in the gcode file. If it's when homing, then the problem will be in the homing files. If it's when running other macro's, that's the place to look.
          lildannyoso 1 Reply Last reply Reply Quote 0
          • lildannyoso
            lildannyoso @Phaedrux last edited by
            @phaedrux
            Here is the complete config file
            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Jul 20 2020 19:57:06 GMT-0500 (Central Daylight Time)
            M550 P"Anycubic Predator" ; set printer name
            M665 R227 L440.45 B185 H410 ; Set delta radius, diagonal rod length, printable radius and homed height
            M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
            M552 P192.168.86.37 S1 ; enable network and acquire dynamic address via DHCP
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P0 S0 ; physical drive 0 goes forwards
            M569 P1 S0 ; physical drive 1 goes forwards
            M569 P2 S0 ; physical drive 2 goes forwards
            M569 P3 S0 ; physical drive 3 goes forwards
            M92 X80.00 Y80.00 Z80.00 E415.00 ; set steps per mm
            M566 X1500.00 Y1500.00 Z1500.00 E1500.00 P1 ; set maximum instantaneous speed changes (mm/min)
            M203 X18000.00 Y18000.00 Z18000.00 E10000.00 ; set maximum speeds (mm/min)
            M201 X1500.00 Y1500.00 Z1500.00 E5000.00 ; set accelerations (mm/s^2)
            M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            ; Retraction
            M207 S1.9 F3000 Z0.388 ; Firmware retraction
            M208 Z0 S1 ; set minimum Z
            M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
            M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
            M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
            M591 D0 P7 C"e0stop" L7 R50:200 E15 S0 ; filament sensor connected to e0_stop
            M558 P8 R0.4 C"zprobe.in+zprobe.mod" H10 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
            G31 P100 X0 Y0 Z.1 ; set Z probe trigger value, offset and trigger height
            M557 R180 S20 ; define mesh grid
            M307 H0 A137.8 C533.3 D1.5 V24.3 B0 ; disable bang-bang mode for the bed heater and set PWM limit
            M308 S1 P"e0temp" Y"pt1000" R4700 ; configure sensor 1 as PT1000 on pin e0temp
            M563 P0 S"Hotend" D0 H1 F1 ; define tool 0
            M572 D0 S0.2 ; pressure advance
            M501 ; set the active parameters to those stored in sys/config-override.g
            • lildannyoso
              lildannyoso @deckingman last edited by lildannyoso
              @deckingman I am getting the error while printing. I checked the machine settings in my slicer and it seems to be the issue. The cooling fan number was set to 3. I have set it to 1 and will test it.
              EDIT: Cooling fan number set to 1 in Cura and it now works as intended.
              • lildannyoso
                @phaedrux Here is the output of M122:
                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet Ethernet 1.02 or later
                Board ID: 08DLM-996RU-N8PS4-7JKD6-3S46T-TUB7N
                Used output buffers: 1 of 24 (13 max)
                Static ram: 27980
                Dynamic ram: 92832 of which 20 recycled
                Exception stack ram used: 472
                Never used ram: 9768
                Tasks: NETWORK(ready,636) HEAT(blocked,1224) MAIN(running,1880) IDLE(ready,80)
                Owned mutexes:
                Last reset 00:10:09 ago, cause: power up
                Last software reset time unknown, reason: User, spinning module GCodes, available RAM 9752 bytes (slot 0)
                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                Error status: 0
                MCU temperature: min 23.4, current 33.3, max 33.8
                Supply voltage: min 23.8, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                Date/time: 2022-01-14 17:02:33
                Cache data hit count 1164865633
                Slowest loop: 24.20ms; fastest: 0.12ms
                === Storage ===
                Free file entries: 9
                SD card longest read time 4.6ms, write time 43.6ms, max retries 0
                Hiccups: 0(0), FreeDm: 169, MinFreeDm: 166, MaxWait: 257672ms
                === MainDDARing ===
                Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                === AuxDDARing ===
                Heater 0 is on, I-accum = 0.3
                Heater 1 is on, I-accum = 0.0
                Segments left: 0
                Movement lock held by null
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is doing "M190 S65" in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                Daemon is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 44.25ms; fastest: 0.02ms
                HTTP sessions: 1 of 8
                Interface state active, link 100Mbps full duplex
                === Filament sensors ===
                Extruder 0 sensor: no data received
                • Topic has been marked as a question  Phaedrux Phaedrux
                • Topic has been marked as solved  Phaedrux Phaedrux
