Filament sensor not detecting filament run-out
I recently purchased a BigTreeTech Smart Filament sensor and have been trying to get it to work. When testing to see if it would detect a filament run-out, it did not. I double checked my wiring and that seems to be correct, so the issue must be in my config file. here it is:
; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Jul 20 2020 19:57:06 GMT-0500 (Central Daylight Time); General preferences
M550 P"Anycubic Predator" ; set printer name
M665 R227 L440.45 B185 H410 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M552 P192.168.86.37 S1 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes forwards
M569 P1 S0 ; physical drive 1 goes forwards
M569 P2 S0 ; physical drive 2 goes forwards
M569 P3 S0 ; physical drive 3 goes forwards
M92 X80.00 Y80.00 Z80.00 E415.00 ; set steps per mm
M566 X1500.00 Y1500.00 Z1500.00 E1500.00 P1 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E10000.00 ; set maximum speeds (mm/min)
M201 X1500.00 Y1500.00 Z1500.00 E5000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Retraction
M207 S1.9 F3000 Z0.388 ; Firmware retraction; Axis Limits
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
M591 D0 P7 C"e0stop" L7 R50:200 E15 S0 ; filament sensor connected to e0_stop; Z-Probe
M558 P8 R0.4 C"zprobe.in+zprobe.mod" H10 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
G31 P100 X0 Y0 Z.1 ; set Z probe trigger value, offset and trigger height
M557 R180 S20 ; define mesh grid; Heaters
M307 H0 A137.8 C533.3 D1.5 V24.3 B0 ; disable bang-bang mode for the bed heater and set PWM limit
M308 S1 P"e0temp" Y"pt1000" R4700 ; configure sensor 1 as PT1000 on pin e0temp
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
M563 P0 S"Hotend" D0 H1 F1 ; define tool 0
M572 D0 S0.2 ; pressure advance; Miscellaneous
M501 ; set the active parameters to those stored in sys/config-override.gAny help would be appreciated.
@lildannyoso said in Filament sensor not detecting filament run-out:
You've got your filament monitor disabled.
From the M591 page:
Sn 0 = disable filament monitoring -
@alankilian Wow such an obvious oversight on my part. It works now!
We've all been there.
Sometimes the eyes of the author just CANNOT see obvious mistakes.
I'm glad you got it running!
