Cant connect with PSU conected
hi,
I am doing the first tests of turning on the printer, with a Duet v3 mini, with this result:
I connect it only with the USB cable connected:
Can I connect to DWC
I was able to update the firmware
Panel Due is seen.
3 LEDs light up, two glued to the WIFI connector and another that flashes belowI connect the PSU and remove the USB
- I can not connect
- Panel Due turns on, but can be seen "connecting"
-It looks like a fair, all the lights are on.
Any idea what it could be?
Can you verify the PSU voltage at the input terminals?
Do you see any damage to any chips on the board? Possibly a regulator is damaged.
@phaedrux ok... Thx
