    Tunning temperarure control last more than 30 min
    • peirofundefined
      peirof
      hi,
      I am tuning the temperature control of the Nozzle... but it has been in phase 4 for about 25 min... Is this normal?
      20/1/2022 07:53:20	Auto tune starting phase 4, tuning with fan off
      20/1/2022 07:49:42	Auto tune starting phase 3, heating system settling
      20/1/2022 07:48:31	Auto tune starting phase 1, heater on
      20/1/2022 07:48:26	M303 H1 S240
      Auto tuning heater 1 using target temperature 240.0°C and PWM 1.00 - do not leave printer unattended
      peirofundefined 1 Reply Last reply Reply Quote 0
      • peirofundefined
        peirof @peirof
        @peirof has finished with these results
        20/1/2022 08:15:51	Warning: heater behaviour was not consistent during tuning
        Auto tuning heater 1 completed after 3 idle and 25 tuning cycles in 1644 seconds. This heater needs the following M307 command:
         M307 H1 B0 R3.161 C199.4 D11.35 S1.00 V24.0
        Edit the M307 H1 command in config.g to match this. Omit the V parameter if the heater is not powered from VIN.
          Firmware version?
          What kind of heater is it?
          • peirofundefined
            peirof @Phaedrux
            @phaedrux the heater its Aliexpress generic 24v 50w 6x20... Firmware its 3.3 stable release (not sure, after check...)
            At the moment, after recording the results, it seems that he is going. If it is true, that the temperature oscillates more than before
              Can you show a photo of the hotend so we can see the hot block configuration?
              Have you tried tuning it as a tool with M303 T0 S240?
