    connecting a fan to heater 3
    • da97edundefined
      da97ed
      Hi
      I'm trying to connect a thermostatically controlled fan at the heater 3 pin but I'm not sure how to wire this. The Fan should be Controlled by the MCU temperature.
      This is what I set up in my config.g so far:
      M308 S3 A"MCU" Y"mcu-temp" ;display MCU temp within the graph
      M950 H3 C"exp.heater3" T3 ;creating heater 3
      M950 F3 C"fan3" Q500 ;creating fan 3
      M106 P3 C"MCU" S3 H3 T40:60 ;control Fan 3 thermostatically. start fan at 40 degrees and rise continually PWM Frequency to 255 when the temperature reached 60 degrees.
      I would wire the fan as follows: Connect Fan + to heater3 pin and Fan - to GND.
      Is this correct regarding wiring and my config GCode?
      Thank you all in advance.
      rjenkinsgbundefined 1 Reply Last reply Reply Quote 0
      • rjenkinsgbundefined
        rjenkinsgb @da97ed
        @da97ed said in connecting a fan to heater 3:
        Not sure on the config, but the fan negative should be to the heater pin; the Duet boards switch heater outputs to ground/0V and the positive is the permanent side.
        Robert J.
        Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
        da97edundefined 1 Reply Last reply Reply Quote 0
        • da97edundefined
          da97ed @rjenkinsgb
          @rjenkinsgb did exactly that and fried my board... thanks for nothing
            How exactly did you have it connected?
            How is it fried?
            What Duet board are you using?
            Connecting a fan to a heater port is much the same as connecting a fan to a fan port. + to + and - to -
              rjenkinsgb @da97ed
              That is not possible, just from using the connections I said. You must have something wrong elsewhere.
              This is a typical heater output, grabbed from a Duet board schematic - it has a power MOFSET switch to ground ( - out ) and permanent positive from the fuse, exactly as I described.
              Robert J.
              • da97edundefined
                da97ed @Phaedrux
                @phaedrux I used a duet wifi v1.04.
                Connected the 24V - to exp.heater3 on the expansion header and positive to VIN. Despite the wiring of the Fan to heater3 I didn't change anything.
                After powering up, all my heaters (E0 and Bed) went crazy and started to heat without any command. I immediately killed the power and disconnected the fan. Since, the DIAG LED ist constantly red, so are the LED next to the USB connector and 3.3+(green) and 5V+.
                There are no optical signs of a damage to the board however I am unable to establish a connection to it. I have already tried to erase the FW using the erase Jumper but still I cant connect to it. After 6s the MCU is too hot to touch it.
                Im not sure what went wrong, would appreciate any further help. Thanks
                  rjenkinsgb @da97ed
                  @da97ed
                  Ah.. Duet 2 not Duet 3... Seeing 3s everywhere in the question, it appeared to be a Duet 3.
                  The expansion connector is only low level logic signals and not capable of controlling any heater or fan directly, without a Duex connected to handle the higher voltage and current control needed..
                  I gave the answer to suit a dedicated heater output port, as did Phaedrux; there was unfortunately no clue in the question that your board did not have one.
                  (The Duets I've used do have the heater 3 power connector onboard, as per the circuit fragment, so again no clue of anything different).
                  Robert J.
