    DCS Not Started
    Duet Web Control
    656
    • kzobarlowundefined
      kzobarlow
      Hello all,
      I am currently having issues with my Duet3D Mini 5+ of trying to set-up the SBC, showing this error trying to connect.
      Hardware being used:
      • Duet3D Mini 5+
      • Raspberry Pi 3 Model B+
      • Elecrow 5" Touch Screen
      Set-Up
      I have flashed the DuetPi.zip to the Raspberry and I am able to connect to my wifi network successfully to the Duet Web Control. I made sure there is no SD card in the Duet Mini. Both Raspberry and Duet have their own separate power supply. I also made sure the ribbon is ok with a multimeter and checked the firmware to make sure it is up to date
      I browsed through the forums a bit tried diagnosing and tried using $ sudo journalctl -u duetcontrolserver -e with this result...
      pi@duet3:~ $ sudo journalctl -u duetcontrolserver -e
      Jan 21 12:02:06 duet3 DuetControlServer[3370]: Licensed under the terms of the GNU Public License
      Jan 21 12:02:08 duet3 DuetControlServer[3370]: [info] Settings loaded
      Jan 21 12:02:08 duet3 DuetControlServer[3370]: [info] Environment initialized
      Jan 21 12:02:08 duet3 DuetControlServer[3370]: [fatal] Could not connect to Duet (Error 16. Cannot put line into
      Jan 21 12:02:08 duet3 systemd[1]: duetcontrolserver.service: Failed with result 'protocol'.
      Jan 21 12:02:08 duet3 systemd[1]: Failed to start Duet Control Server.
      Jan 21 12:02:09 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=100ms expired, sch
      Jan 21 12:02:09 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counte
      Jan 21 12:02:09 duet3 systemd[1]: Stopped Duet Control Server.
      Jan 21 12:02:09 duet3 systemd[1]: Starting Duet Control Server...
      Jan 21 12:02:09 duet3 DuetControlServer[3402]: Duet Control Server v3.3.0
      Jan 21 12:02:09 duet3 DuetControlServer[3402]: Written by Christian Hammacher for Duet3D
      Jan 21 12:02:09 duet3 DuetControlServer[3402]: Licensed under the terms of the GNU Public License
      Jan 21 12:02:11 duet3 DuetControlServer[3402]: [info] Settings loaded
      Jan 21 12:02:11 duet3 DuetControlServer[3402]: [info] Environment initialized
      Jan 21 12:02:11 duet3 DuetControlServer[3402]: [fatal] Could not connect to Duet (Error 16. Cannot put line into
      Jan 21 12:02:11 duet3 systemd[1]: duetcontrolserver.service: Failed with result 'protocol'.
      Jan 21 12:02:11 duet3 systemd[1]: Failed to start Duet Control Server.
      Jan 21 12:02:12 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=100ms expired, sch
      Jan 21 12:02:12 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counte
      Jan 21 12:02:12 duet3 systemd[1]: Stopped Duet Control Server.
      Jan 21 12:02:12 duet3 systemd[1]: Starting Duet Control Server...
      Running out of ideas what to do or look for, any help will be appreciated
      • chrishammundefined
        chrishamm administrators @kzobarlow
        @kzobarlow I suggest you flash the DuetPi image once again to your microSD card. It seems like something blocks access to the TfrRdy pin which is why you get Error 16 in the DCS log.
        Duet software engineer
        kzobarlowundefined 1 Reply Last reply Reply Quote 0
          kzobarlow @chrishamm
          @chrishamm
          I have tried this which worked having both boards by itself. But once I plugged everything up to the 3D printer I got the same error. I separated the board and pi once again then flashed the pi but now still getting the error again....
          sonderzugundefined 1 Reply Last reply Reply Quote 0
          • sonderzugundefined
            sonderzug @kzobarlow
            @kzobarlow Hi, I had the same error when I first set up my Duet 3 5+ mini with a Pi.
            I had the ribbon cable plugged backwards into the Duet, which was possible since the connector doesn't have a indexing indentation. Double-check against the online documentation for the 6HC that the ribbon cable is plugged in correctly, e.g. the position of the red wire is important.
            Once I had it correct everything came together without further issues.
              kzobarlow @sonderzug
              @sonderzug
              Seeing the mini has a key slot I don't see how it's possible to plug it in incorrectly?
              ![alt text](cb13487b-588b-4687-af93-b84a0ce8d68c-image.png image url)
              I made sure the red band on the cable seats on the bottom row of the pi as well
                Do you have a different pi to test with?
                  @kzobarlow sorry, must have remembered wrongly. I might have had the cable plugged in backwards to the Pi but that doesn't seem the case with your setup.
                    kzobarlow @Phaedrux
                    @phaedrux
                    not on hand but may try it at this point
                      kzobarlow
                      Upgraded/Changed to a Raspberry Pi 4 Model B and still getting the same error as before....
                      Edit:
                      SD Card was re flashed before doing anything
                        Thanks for testing with a new Pi. Can you confirm that you reflashed with the latest Duet Pi image download?
                        If you enable logging again do you get the same errors?
                          kzobarlow @Phaedrux
                          @phaedrux
                          Yes SD card was re-flashed with the latest image
                          This is what I got running $ sudo journalctl -u duetcontrolserver -e
                          Jan 31 19:48:24 duet3 DuetControlServer[10320]: [fatal] Could not connect to Due
                          Jan 31 19:48:24 duet3 systemd[1]: duetcontrolserver.service: Failed with result
                          Jan 31 19:48:24 duet3 systemd[1]: Failed to start Duet Control Server.
                          Jan 31 19:48:24 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=
                          Jan 31 19:48:24 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart j
                          Jan 31 19:48:24 duet3 systemd[1]: Stopped Duet Control Server.
                          Jan 31 19:48:24 duet3 systemd[1]: Starting Duet Control Server...
                          Jan 31 19:48:25 duet3 DuetControlServer[10354]: Duet Control Server v3.3.0
                          Jan 31 19:48:25 duet3 DuetControlServer[10354]: Written by Christian Hammacher f
                          Jan 31 19:48:25 duet3 DuetControlServer[10354]: Licensed under the terms of the
                          Jan 31 19:48:25 duet3 DuetControlServer[10354]: [info] Settings loaded
                          Jan 31 19:48:25 duet3 DuetControlServer[10354]: [info] Environment initialized
                          Jan 31 19:48:26 duet3 DuetControlServer[10354]: [fatal] Could not connect to Due
                          Jan 31 19:48:26 duet3 systemd[1]: duetcontrolserver.service: Failed with result
                          Jan 31 19:48:26 duet3 systemd[1]: Failed to start Duet Control Server.
                          Jan 31 19:48:26 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=
                          Jan 31 19:48:26 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart j
                          Jan 31 19:48:27 duet3 systemd[1]: Stopped Duet Control Server.
                          Jan 31 19:48:27 duet3 systemd[1]: Starting Duet Control Server...
                          Jan 31 19:48:28 duet3 DuetControlServer[10387]: Duet Control Server v3.3.0
                          Jan 31 19:48:28 duet3 DuetControlServer[10387]: Written by Christian Hammacher f
                          Jan 31 19:48:28 duet3 DuetControlServer[10387]: Licensed under the terms of the
                          lines 980-1001/1001 (END)
                            Have you tested the Duet in standalone mode to see if it's otherwise functional? What firmware is flashed on it?
                            Is the touch screen powered by it's own supply?
                              @kzobarlow Please use journalctl -u duetcontrolserver -e --no-pager because the error mesage is truncated. If it is the same "Cannot put line into event mode" error message (also truncated before), it indicates that something keeps blocking a required GPIO pin.
                              If this is the case, please run the following commands:
                              sudo systemctl stop duetcontrolserver
                              sudo gpioinfo
                              If you get an error invoking gpioinfo, try installing gpiod (sudo apt install gpiod) first. The line starting with line 25 shows you which program blocks access to the GPIO pin.
                                kzobarlow @Phaedrux
                                @phaedrux
                                Yes I tested it without the Pi connected and was able to interact with it through my browser
                                The touch screen is powered by the pi but I switched to a PC monitor powered independently so I can see the terminal screen better but still have the same problem
                                  @chrishamm
                                  Result from journalctl -u duetcontrolserver -e --no-pager
                                  eb 01 21:08:04 duet3 DuetControlServer[21900]: Duet Control Server v3.3.0
                                  Feb 01 21:08:04 duet3 DuetControlServer[21900]: Written by Christian Hammacher for Duet3D
                                  Feb 01 21:08:04 duet3 DuetControlServer[21900]: Licensed under the terms of the GNU Public License Version 3
                                  Feb 01 21:08:05 duet3 DuetControlServer[21900]: [info] Settings loaded
                                  Feb 01 21:08:05 duet3 DuetControlServer[21900]: [info] Environment initialized
                                  Feb 01 21:08:06 duet3 DuetControlServer[21900]: [fatal] Could not connect to Duet (Timeout while waiting for transfer ready pin)
                                  Feb 01 21:08:06 duet3 systemd[1]: duetcontrolserver.service: Failed with result 'protocol'.
                                  Feb 01 21:08:06 duet3 systemd[1]: Failed to start Duet Control Server.
                                  Feb 01 21:08:06 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=100ms expired, scheduling restart.
                                  Feb 01 21:08:06 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 623.
                                  Feb 01 21:08:06 duet3 systemd[1]: Stopped Duet Control Server.
                                  Feb 01 21:08:06 duet3 systemd[1]: Starting Duet Control Server...
                                  After tying this
                                  sudo gpioinfo
                                  pi@duet3:~ $ sudo gpioinfo
                                  gpiochip0 - 58 lines:
                                  	line   0:     "ID_SDA"       unused   input  active-high
                                  	line   1:     "ID_SCL"       unused   input  active-high
                                  	line   2:       "SDA1"       unused   input  active-high
                                  	line   3:       "SCL1"       unused   input  active-high
                                  	line   4:  "GPIO_GCLK"       unused   input  active-high
                                  	line   5:      "GPIO5"       unused   input  active-high
                                  	line   6:      "GPIO6"       unused   input  active-high
                                  	line   7:  "SPI_CE1_N"   "spi0 CS1"  output   active-low [used]
                                  	line   8:  "SPI_CE0_N"   "spi0 CS0"  output   active-low [used]
                                  	line   9:   "SPI_MISO"       unused   input  active-high
                                  	line  10:   "SPI_MOSI"       unused   input  active-high
                                  	line  11:   "SPI_SCLK"       unused   input  active-high
                                  	line  12:     "GPIO12"       unused   input  active-high
                                  	line  13:     "GPIO13"       unused   input  active-high
                                  	line  14:       "TXD1"       unused   input  active-high
                                  	line  15:       "RXD1"       unused   input  active-high
                                  	line  16:     "GPIO16"       unused   input  active-high
                                  	line  17:     "GPIO17"       unused   input  active-high
                                  	line  18:     "GPIO18"       unused   input  active-high
                                  	line  19:     "GPIO19"       unused   input  active-high
                                  	line  20:     "GPIO20"       unused   input  active-high
                                  	line  21:     "GPIO21"       unused   input  active-high
                                  	line  22:     "GPIO22"       unused   input  active-high
                                  	line  23:     "GPIO23"       unused   input  active-high
                                  	line  24:     "GPIO24"       unused   input  active-high
                                  	line  25:     "GPIO25"       unused   input  active-high
                                  	line  26:     "GPIO26"       unused   input  active-high
                                  	line  27:     "GPIO27"       unused   input  active-high
                                  	line  28: "RGMII_MDIO"       unused   input  active-high
                                  	line  29:  "RGMIO_MDC"       unused   input  active-high
                                  	line  30:       "CTS0"       unused   input  active-high
                                  	line  31:       "RTS0"       unused   input  active-high
                                  	line  32:       "TXD0"       unused   input  active-high
                                  	line  33:       "RXD0"       unused   input  active-high
                                  	line  34:    "SD1_CLK"       unused   input  active-high
                                  	line  35:    "SD1_CMD"       unused   input  active-high
                                  	line  36:  "SD1_DATA0"       unused   input  active-high
                                  	line  37:  "SD1_DATA1"       unused   input  active-high
                                  	line  38:  "SD1_DATA2"       unused   input  active-high
                                  	line  39:  "SD1_DATA3"       unused   input  active-high
                                  	line  40:  "PWM0_MISO"       unused   input  active-high
                                  	line  41:  "PWM1_MOSI"       unused   input  active-high
                                  	line  42: "STATUS_LED_G_CLK" "led0" output active-high [used]
                                  	line  43: "SPIFLASH_CE_N" unused input active-high
                                  	line  44:       "SDA0"       unused   input  active-high
                                  	line  45:       "SCL0"       unused   input  active-high
                                  	line  46: "RGMII_RXCLK" unused input active-high
                                  	line  47: "RGMII_RXCTL" unused input active-high
                                  	line  48: "RGMII_RXD0"       unused   input  active-high
                                  	line  49: "RGMII_RXD1"       unused   input  active-high
                                  	line  50: "RGMII_RXD2"       unused   input  active-high
                                  	line  51: "RGMII_RXD3"       unused   input  active-high
                                  	line  52: "RGMII_TXCLK" unused input active-high
                                  	line  53: "RGMII_TXCTL" unused input active-high
                                  	line  54: "RGMII_TXD0"       unused   input  active-high
                                  	line  55: "RGMII_TXD1"       unused   input  active-high
                                  	line  56: "RGMII_TXD2"       unused   input  active-high
                                  	line  57: "RGMII_TXD3"       unused   input  active-high
                                  gpiochip1 - 8 lines:
                                  	line   0:      "BT_ON"       unused  output  active-high
                                  	line   1:      "WL_ON"       unused  output  active-high
                                  	line   2: "PWR_LED_OFF" "led1" output active-low [used]
                                  	line   3: "GLOBAL_RESET" unused output active-high
                                  	line   4: "VDD_SD_IO_SEL" "vdd-sd-io" output active-high [used]
                                  	line   5:   "CAM_GPIO"       unused  output  active-high
                                  	line   6:  "SD_PWR_ON" "sd_vcc_reg"  output  active-high [used]
                                  	line   7:    "SD_OC_N"       unused   input  active-high
                                  pi@duet3:~ $ ^C
                                  If I'm seeing this right... I don't see anything that's tied to 25?
                                    @kzobarlow That's a different error message now. Please ensure you do not have a microSD card in the Duet.
                                      @chrishamm
                                      No SD card is present in the Duet Mini board
                                        kzobarlow
                                        So again.... if I'm seeing this right "GPIO25" reads unused still and unless I'm missing something don't see anything getting blocked?
                                          @kzobarlow Does the DIAG LED on the Duet blink or is it dimmed? Do you have firmware 3.3 installed on the board? If in doubt, you can flash it again. You can find firmware version 3.3 here ( Duet3Firmware_Mini5plus.uf2).
                                          If you have a multimeter, you can also check continuity between pin 22 of the Pi and Duet. When you're at it, you could check pin 17 as well, because that signal is required for SPI comms, too.
                                            @chrishamm
                                            Still getting DCS Error...
                                            "Does the DIAG LED on the Duet blink or is it dimmed?"
                                            • Not sure which one that is, looking at the wiring diagram LED V FUSED and LED 12V are the only ones active and showing a solid light.
                                            • All other lights LED ACT, LED STATUS, LED +5V, and LED +3.3V do not turn on even during powering on the PSU
                                            • Again Pi is powered by an independent 5V PSU and Mini is powered by a 24 PSU
                                            "Do you have firmware 3.3 installed on the board?"
                                            • Yes checked with M115
                                            • Reflashed using Fallback procedure #1 and Fallback procedure #2
                                            • SD Card was removed after confirming again with YAT RRF is up to date
                                            "If you have a multimeter, you can also check continuity between pin 22 of the Pi and Duet. When you're at it, you could check pin 17 as well, because that signal is required for SPI comms, too."
                                            • Checked with a multimeter and continuity is fine for both pins
                                            Trying terminal again
                                            Feb 06 22:19:30 duet3 DuetControlServer[4022]: Duet Control Server v3.3.0
                                            Feb 06 22:19:30 duet3 DuetControlServer[4022]: Written by Christian Hammacher for Duet3D
                                            Feb 06 22:19:30 duet3 DuetControlServer[4022]: Licensed under the terms of the GNU Public License Version 3
                                            Feb 06 22:19:30 duet3 DuetControlServer[4022]: [info] Settings loaded
                                            Feb 06 22:19:31 duet3 DuetControlServer[4022]: [info] Environment initialized
                                            Feb 06 22:19:31 duet3 DuetControlServer[4022]: [fatal] Could not connect to Duet (Timeout while waiting for transfer ready pin)
                                            Feb 06 22:19:31 duet3 systemd[1]: duetcontrolserver.service: Failed with result 'protocol'.
                                            Feb 06 22:19:31 duet3 systemd[1]: Failed to start Duet Control Server.
                                            Feb 06 22:19:32 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=100ms expired, scheduling restart.
                                            Feb 06 22:19:32 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 87.
                                            Feb 06 22:19:32 duet3 systemd[1]: Stopped Duet Control Server.
                                            Feb 06 22:19:32 duet3 systemd[1]: Starting Duet Control Server...
                                            pi@duet3:~ $ gpioinfo
