    Modifying built-in macros
    410
    • TomFundefined
      TomF
      This is most likely me missing the obvious, but how can I find, modify and save 'built-in' macros? For example pause.g, which I'd like to have a relative movement to get the bed away from a hot nozzle, or the macro to change filament that invokes load and unload filament macros.
      Thanks,
      Rushmere3Dundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
      • Rushmere3Dundefined
        Rushmere3D @TomF
        @tomf
        To edit system files (Pause.g, Resume.g etc) You would find them via Files - System and click them, this opens a text editor.
        To edit Macro's, you find them via Files - Macros and right click to open a menu and then Edit file.
        Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
        TomFundefined 1 Reply Last reply Reply Quote 0
        • TomFundefined
          TomF @Rushmere3D
          @rushmere3d said in Modifying built-in macros:
          @tomf
          That was the first place I looked but those macros aren't there or they are not visible. There are 2 directories within System (System directory and Firmware directory) and neither have those macros, unless perhaps they are hidden in a 'bin' I have also looked in 'Macros' and they aren't there either.
            dc42 administrators @TomF
            @tomf if you have pause.g and resume.g then they should be in the System directory. Perhaps you don't have them? Can you see config.g in the System directory?
            • fcwiltundefined
              fcwilt @TomF
              @tomf
              The "built-in" macros are not really built-in - you have to create them if you need/want them.
              • TomFundefined
                TomF @dc42
                Yes. config.g is there, so I guess I don't have the others. I though they were somehow built in based on the explanation in the M226 documentation "Initiates a pause in the same way as if the pause button is pressed, except that execution of all prior GCode commands in the same input stream is completed first. Then the SD card input stream is paused and file sys/pause.g is run" so I was looking for a file. Are there examples of pause, resume, load, etc. that I can use?
                • TomFundefined
                  TomF @fcwilt
                  @fcwilt said in Modifying built-in macros:
                  @tomf
                  I'm now realising that! I will have to find some examples somewhere. Any suggestions?
                  • fcwiltundefined
                    fcwilt @TomF
                    @tomf said in Modifying built-in macros:
                    @tomf
                    Perhaps these will help you get started.
                    Here is my pause.g:
                    M291 R"Pausing Print" P"Please wait..." T0
                    M83                 ; relative extruder moves
                    G1 E-1 F3600        ; retract filament (see resume.g)
                    G91                 ; relative moves
                    G1 Z10 F9999        ; move nozzle out of the way - step 1 (max speed)
                    G90                 ; absolute moves
                    G1 X0 Y150 F6000    ; move nozzle out of the way - step 2
                    M291 R"Print Paused" P"Done" T1
                    Here is my resume.g:
                    M291 R"Resuming print" P"Please wait..." T0
                    G1 R1 Z5    ; move  nozzle to 5mm above resume point (Z)
                    G1 R1 X0 Y0 ; move  nozzle to resume point (XY)
                    G1 R1 Z0    ; lower nozzle to resume point (Z)
                    G1 E1 F3600 ; undo the retraction done in pause.g
                    M291 R"Print Resumed" P"Done" T1
                    TomFundefined 1 Reply Last reply Reply Quote 2
                    • TomFundefined
                      TomF @fcwilt
                      @fcwilt
                      Great, thanks! I found some through the Duet macros documentation, so I should hopefully be able to work out something from these.
