Duet no longer responsive
Checked LEDs and connected via USB without panel on and I still get nothing...can't even home motors. However, as inspecting I noticed the Wifi light is not on. Plus, when connected to Repetier, any commands given times out, and no icon for bed heater appears.
Which step did you get to?
@alankilian well I went ahead and formatted the SD card, then reloaded the firmware and I got it to begin to behave normal, but the Wifi dongle kept flashing and the Panel was giving me the same WIFI error message over and over "Could not connect". I then tried to heat my bed and print standalone then everything froze, and Im back to square 1.
Alright so this is where I'm at:
Blue WIFI light is constantly blinking still. When I try to connect to YAT or Repetier to update the WIFI password, no dice. Nothing saves. In Repetier, all I get back are "x" Commands waiting with no response. If I add 3 codes, it says 3 waiting, if that makes sense.Literally the only thing that has changed since successfully printing yesterday is I changed the name of the old WIFI login, and just need the Duet to get updated with the new password. But it seems I cant get control if it in any way.
@azerate which Duet do you have: Duet 2 WiFi, or Duet 3 Mini WiFi ?
You said you "got it to begin to behave normal". Was it responding to commands sent from YAT?
@azerate said in Duet no longer responsive:
The steps in the diagnosis page I posted need to be followed in order one-at-a-time in order for anyone to be able to give you reasonable assistance.
I'm sorry for being a pain, but I can't be much help if you randomly change things, update firmware and then say nothing works.
It's mostly me not understanding your system better, I'm sorry for not being able to help you more.
@dc42 While it connected via USB, no. It did not respond in YAT.
It behaves normal until the Panel reports the WIFI module being idle. After which, it's a brick.
Everything seems to be fixed at least for now.
I turned the machine and disconnected the Panel. connected to USB then loaded Yat. Wifi errors continued for several tries until it stuck. I'm assuming every other attempt was at the moment the board was cycling fault codes, but YAT only showed me once on this attempt.Thanks for everyone's help. Sorry if I wasted time, but it took me over 6 hours to get this guy connected again.
Can you send. M122 and share the results?
