    Crashed with Beta Firmware and BLTouch?
    Beta Firmware
    • DavidHyperundefined
      DavidHyper
      hello,
      my BLTouch doesn't deployed after i paused and stop a print and started a new print.
      This happens the second time.
      I have a BLTouch V3.1 and a Duet 6HC in SBC Mode with Firmware Duet 3 MB6HC 3.4.0beta7+5 (2022-01-13)
      config.g
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Dec 27 2021 17:19:28 GMT+0100 (Mitteleuropäische Normalzeit)
      ; ======== General preferences =========
      M80 C"pson" 									   ; Enable ATX
      M550 P"duet3"                                      ; set printer name
      M669 K1                                            ; select CoreXY mode
      ; ======== Network ========
      M586 P1 S1                                         ; enable FTP
      M586 P2 S1                                         ; enable Telnet
      ; ======= Drives ========
      M569 P0 S0 D3                                      ; physical drive 0 goes backwards
      M569 P1 S0 D3                                      ; physical drive 1 goes backwards
      M569 P2 S0                                         ; physical drive 2 goes backwards
      M569 P3 S0                                         ; physical drive 3 goes backwards
      M569 P4 S0                                         ; physical drive 4 goes backwards
      M584 X0 Y1 Z2:3 E4                                 ; set drive mapping
      M92  X100.00 Y100.00 Z1600.00 E415.00               ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X20000.00 Y20000.00 Z800.00 E1200.00          ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z200.00 E1000.00            ; set accelerations (mm/s^2)
      M204 P2000 T3000								   ; set Printing and Travel Accelations (mm/s^2)
      M906 X1500 Y1500 Z1300 E800 I30                     ; set motor currents (mA) and motor idle factor in per cent
      ; ======== Axis Limits ========
      M208 X-28 Y-30 Z0 S1                                   ; set axis minima
      M208 X336 Y310 Z410 S0                             ; set axis maxima
      ; ======== Endstops ========
      M574 X1 S3                                         ; configure sensorless endstop for low end on X
      M574 Y1 S3                                         ; configure sensorless endstop for low end on Y
      M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
      ; ======== Z-Probe ========
      M950 S0 C"io4.out"                                 ; create servo pin 0 for BLTouch
      M558 P9 C"io4.in" H5 F300 T15000 A3                ; set Z probe type to bltouch and the dive height + speeds
      G31 P25 X-27.5 Y-21 Z1.959                        ; set Z probe trigger value, offset and trigger height
      M557 X10:285 Y10:285 P7:7                            ; define mesh grid
      ; ======== Independent Z-Leveling ========
      M671 X-64.74:364.74 Y150:150 S3	F1 				   ; define where are the leadscrew
      ; ======== Heaters ========
      M308 S0 P"temp0" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"out0" T0                              ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
      ; ======== Fans ========
      M950 F0 C"out8" Q500                               ; create fan 0 on pin fan0 and set its frequency
      M106 P0 C"Fan Cooling" S0 H-1                      ; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"out7" Q500                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 C"Fan Hotend" S1 H1 T45                    ; set fan 1 name and value. Thermostatic control is turned on
      ; ========  Tools ========
      ; ========  Miscellaneous ========
      M911 S20 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      T0                                                 ; select first tool
      ; ======= Machine =======
      M950 P2 C"out2" ; define out2 as light
      M42 P2 S1 ; Switch Light on on StartUp
      M950 J8 C"^io8.in"                                 ; Map io8.in to Emergency Stop
      M581 P8 T0 C0 R0                                   ; Configuring Trigger0 (Emergency Stop)
      M582 T0						                       ; Check actual State
      M575 P1 B57600 S2								   ; Settings for Neopixel Communication
      ; ======== Sensorless Homing ========
      M915 X Y S3 R0 F0
      ; ======== Acc Sensor ==========
      ; M955 P0 C"spi.cs3+spi.cs2" I24
      ; M593 P"EI3" F65.2  									; use ZVD input shaping to cancel ringing at xx Hz
      ; ======== Firmware Retraction =========
      M207 S0.65 F2400 Z0.0							   ; Firmware Retraction
      ; ======== Settings config-override ========
      M501											   ; Load settings
      ; ======== Reset Routines ========
      M280 P0 S160 									   ; Reset BL-Touch
      deploy
      ; deployprobe.g
      ; called to deploy a physical Z probe
      M280 P0 S160 	; Reset BLTouch
      G4 P100			; Wait 100ms
      M280 P0 S10 	; deploy BLTouch
      G4 P300			; Wait 100ms
      M280 P0 S60  	; Touch Switch Mode BLTouch
      G4 P200			; Wait 200ms
      retract
      ; retractprobe.g
      ; called to retract a physical Z probe
      M280 P0 S90 ; retract BLTouch
      homez.g
      ; homez.g
      ; called to home the Z axis
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Dec 27 2021 17:19:29 GMT+0100 (Mitteleuropäische Normalzeit)
      G91            ; relative positioning
      G90            ; absolute positioning
      G1 X177.5 Y171 F6000 ; go to first probe point
      M401           ; Deploy Probe for Safety --> Workaround for the moment!?1?!?!??!?!?!
      G30            ; home Z by probing the bed
      ;G91           ; relative positioning
      ;G1 Z5 F100    ; lift Z relative to current position
      ;G90           ; absolute positioning
      Does anyone else have these problem?
        Phaedrux Moderator @DavidHyper
        @davidhyper said in Crashed with Beta Firmware and BLTouch?:
        ; deployprobe.g        ; called to deploy a physical Z probe        ;        ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Dec 27 2021 17:19:28 GMT+0100 (Mitteleuropäische Normalzeit)        M280 P0 S160 	; Reset BLTouch        G4 P100			; Wait 100ms        M280 P0 S10 	; deploy BLTouch        G4 P300			; Wait 100ms        M280 P0 S60  	; Touch Switch Mode BLTouch        G4 P200			; Wait 200ms
        Have you tried with just the deploy command?
        When you say crashed in the title, what do you mean?
        Can you test with 3.4 beta 7+7?
        DavidHyperundefined PCRundefined 2 Replies Last reply Reply Quote 0
          DavidHyper @Phaedrux
          @phaedrux because my bltouch doesn't deploy my nozzle dive into the bed.
          I give it a try with the newer beta.
          • PCRundefined
            PCR @Phaedrux
            @phaedrux it's a bug in 3.4b7
            Think @dc42 is aware
