Nooo....not again...!!!!!!!!
@peirof can you post your config?
@jay_s_uk sure
Drivers in 0.1, 0.2, and 0.3 controls Z
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"V-Core 3" ; set printer name M669 K1 ; CoreXY G29 S1 ; Set Units to Millimeters ; Network M587 S"PT_2" P"a1b2c3d4" M552 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ;Panel Due M575 P1 B57600 ; Drives M569 P0.0 S0 D3 ; physical drive 0.0 goes forwards M569 P0.1 S0 D3 ; physical drive 0.1 goes forwards M569 P0.2 S0 D3 ; physical drive 0.2 goes forwards M569 P0.3 S1 D3 ; physical drive 0.3 goes forwards M569 P0.4 S1 D3 ; physical drive 0.4 goes forwards M569 P0.5 S1 D3 ; physical drive 0.5 goes forwards M584 X0.4 Y0.3 Z0.6:0.1:0.2 E0.5 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z800.00 ; set steps per mm M906 X1000 Y1000 Z800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout M566 X400.00 Y400.00 Z6.00 E120.00 P1 ; set maximum instantaneous speed changes (mm/min) M203 X10800.00 Y10800.00 Z1000.00 E3600.00 ; set maximum speeds (mm/min) M201 X3000.00 Y3000.00 Z100.00 E3600.00 ; set accelerations (mm/s^2) ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X410 Y400 Z400 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io0.in" ; configure active high endstops M574 Y2 S1 P"io1.in" ; configure active high endstops M574 Z1 S2 ; configure Z-probe endstop for low end on Z M671 X-4.5:200:304.5 Y-4.52:405:-4.52 S5 ; define positions of Z leadscrews or bed levelling screws M557 X20:380 Y20:380 P5 ; define 5x5 mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed" ; configure sensor 0 as thermistor on pin temp0 M307 H1 B0 R3.161 C199.4 D11.35 S1.00 V24.0 M950 H0 C"out0" T0 ; create bed heater output on out5 and map it to sensor 0 M307 H0 B0 R0.776 C301.3 D5.65 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S110 ; set temperature limit for heater 0 to 110C ;; Run Bed PID Tune!! Bellow is an example for a 300x300 bed ;; M307 H0 A303.1 C356.7 D1.4 S1.00 V24.0 B0 ; Fans M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency M106 P0 C"Ventilador Hotend" S0 H1 T45 L255 ; set fan 0 name and value. Thermostatic control turned on for Hotend M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency M106 P1 C"Ventilador Capa" S0 H-1 L255 ; set fan 1 name and value. Thermostatic control is turned off ; Tools M563 P0 D0 H1 F1 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M950 H1 C"out1" T1 ; create nozzle heater output on out2 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S250 ; set the maximum temperature in C for heater ; EVA 2 / BMG / E3D V6 M92 E830 ; set extruder steps per mm, 0.9 angle/step (LDO Pancake) M906 E800 ; set extruder motor current (mA) and idle factor in per cent M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.060000e-8 A"Hotend" ;; Run Heater PID Tune!! ;; M307 H1 A751.5 C196.6 D4.7 S1.00 V23.9 B0 ; BLTouch M950 S0 C"io2.out" ; Create a servo pin on io7 M558 P9 C"io2.in" H5 F240 T10800 A5 ; set Z probe type to unmodulated and the dive height + speeds G31 P25 X-28.00 Y-13.00 Z0.90 ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed T0 ; Pressure Advance M572 D0 S0.10
@peirof theres probably some default mapping somewhere that maps driver 0 to something else.
Try addingU0.0
to your M584 and see if the problem goes away -
@peirof said in Nooo....not again...!!!!!!!!:
According to that, you have drivers 6,1 and 2 of the main board controlling Z. Drivers 0 isn't connected to anything.
Looking at your config.g, that's definitely not true. There, you map Z with
M584
to 0.6, 0.1 and 0.2. In the "Drives" section above,M569 P0.6 S0 D3
is missing, i.e. drive 0.6 is not defined.And, as a side note: try to keep your gcodes in sync with the comments. "physical drive 0.3 goes forwards" is just the opposite of what the gcode does. Same is true for drives 0.4 and 0.5. With "S1" they go backwards.
@infiniteloop no.... These is edited config.g,for following use duet, but by default its connected to 0.1,for check it is stepper problem I have connected to 0.6
@peirof Don't confuse me (and don't be confused yourself): the first Z-stepper was originally connected to 0.0 (not 0.1 - that's the second of three steppers for Z). As you ran into problems with port 0.0, you switched to 0.6. Now, you still have to add the
M569
gcode to match your actual assignment. -
forgive the error, I have corrected the error, Driver 0.0 DOES work.
What was the error, that I have started to assign the engines with M569 in 0.1, and it was 0.0
the repaired config.g (extract):
; Drives M569 P0.0 S0 D3 ; physical drive 0.0 goes forwards spare test M569 P0.1 S0 D3 ; physical drive 0.1 goes forwards M569 P0.2 S0 D3 ; physical drive 0.2 goes forwards M569 P0.3 S1 D3 ; physical drive 0.3 goes forwards M569 P0.4 S1 D3 ; physical drive 0.4 goes forwards M569 P0.5 S1 D3 ; physical drive 0.5 goes forwards M584 X0.4 Y0.3 Z0.0:0.1:0.2 E0.5 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation
thx, and sorry
@peirof No reason to be sorry. The main thing is to not getting confused - that are just gcodes
Does that photo show chunks missing from the driver chip and a missing resistor?
