    G32 and This kinematics does not support auto-calibration
    • TimsWorkshopundefined
      TimsWorkshop
      Good morning/afternoon all!
      I've setup a rail system and a new E3D hotend for my Ender 5 Plus and while I've been working on recalibrating my Bed size, offsets, and mesh coordinates, I've run into a problem with my G32 command telling me the kinematics don't support the auto calibration.
      I've looked through a few previous posts and read the gcode documentation, and while I have 4 coordinates configured in M671 and 4 probe points configured in G30, I still get the above error. I can't seem to find the spot where this error is coming from...
      I can run G32 and it probes my 4 points as expected, but I can't get any output to adjust me screws.
      I've put my files below, would love any insight someone might have:
      config.g
      ; Configuration file for Duet WiFi (firmware version 3.4 beta 7)
      M550 P"Stargate SG-1 - Jackson"                    ; set printer name
      ; Global Variables
      global g_move_forward        = 5          ; can be used to always move Z to known height
      global g_move_back           = -{global.g_move_forward}          ; can be used to always move Z to known height
      global g_axes_speeds	     = 6000 ; Speeds to move axes during homing
      ; Z-Lead Screw Positions
      global l_zlead_screw_x		 = 30
      global r_zlead_screw_x		 = 335
      global zlead_screw_y		 = 208
      ; 4-P Bed Levelling Positions
      global fl_screw_x		 = 30
      global fl_screw_y		 = 76.8
      global fr_screw_x		 = 310
      global fr_screw_y		 = 76.8
      global bl_screw_x		 = 30
      global bl_screw_y		 = 338
      global br_screw_x		 = 310
      global br_screw_y		 = 338
      global g_print_end_mode      = "HEAT OFF" ; determines if heaters are turned off when print is done
      global g_map_mode            = "FULL"     ; determines which kind of height map is created/loaded
      global g_probe_mode          = "TWO"      ; determines if z proving used consecutive or averaging
      global g_level_mode          = "3PT"      ; determines if 3 or 4 points are used for leveling
      ; BL-Touch Probe Offsets
      global probe_offset_x		 = -39		  ; BL Touch X offset
      global probe_offset_y		 = 39.3		  ; BL Touch Y offset
      global probe_offset_z		 = 1.523	  ; BL Touch Z offset
      M569 P0 S0                                         ; X drive 0 goes backwards
      M569 P1 S1                                         ; Y drive 1 goes backwards
      M569 P2 S1                                         ; Z1 drive 2 goes forwards
      M569 P3 S0                                         ; E drive 3 goes backwards
      M584 X0 Y1 Z2 E3                                   ; set drive mapping
      ; Movement
      M92 X80.00 Y80.00 Z800.00 E409                  ; set steps per mm
      M566 X900.00 Y900.00 Z300.00 E2000.00 P1           ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z900.00 E6000.00            ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z500.00 E3000.00              ; set accelerations (mm/s^2) 200
      M906 X800 Y800 Z800 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
      ; Axis Min/Max
      M208 S1 X25 Y9 Z-10                                 ; set axis minima
      M208 S0 X380 Y350 Z400                              ; set axis maxima
      M574 X2 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
      M574 Y2 S1 P"ystop"                                ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
      ; Kinematics
      M669 K0
      ; Custom Probe config file
      M98 P"configs/probe_config.g"                         ; Config settings for my EZABL probe
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S285                                       ; set temperature limit for heater 1 to 280C
      ;M950 F0 C"nil"									   ; Free up pin F0
      ;M950 F0 C"fan1" Q500							   ; Assign Fan0 for Prusa Slicer
      ;M106 P0 S0 H-1
      M950 F0 C"nil"
      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan3 and set its frequency
      M106 P0 S0 H1 T45                                  ; set fan 0 value. Thermostatic control is turned on
      ; Custom Configurations
      ; Filament Runout Sensor
      M591 D0 P1 C"e0stop" S1
      ; TFT Display Config
      M575 P1 S1 B57600
      M501                                               ; load saved parameters from non-volatile memory
      bed.g
      ; bed.g
      ; Probe points for my 4x Adjustment Knobs
      M671 X{global.fl_screw_x}:{global.fr_screw_x}:{global.bl_screw_x}:{global.br_screw_x} Y{global.fl_screw_y}:{global.fr_screw_y}:{global.bl_screw_y}:{global.br_screw_y}
      ; Home and probe near bed spring knobs
      ; Lead Screw Positions
      G28 Z; home
      G30 P0 X{global.probe_offset_x} + {global.fl_screw_x} Y{global.probe_offset_y} + {global.fl_screw_y} Z-9999 ; Front-Left
      G30 P1 X{global.probe_offset_x} + {global.fr_screw_x} Y{global.probe_offset_y} + {global.fr_screw_y} Z-9999 ; Front-Right
      G30 P3 X{global.probe_offset_x} + {global.bl_screw_x} Y{global.probe_offset_y} + {global.bl_screw_y} Z-9999; Back-Left
      G30 P2 X{global.probe_offset_x} + {global.br_screw_x} Y{global.probe_offset_y} + {global.br_screw_y} Z-9999 S4; Back-Right
      Ender 5 Plus - E3D Hemera Hotend - Duet 2 Wifi
      fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @TimsWorkshop
        @infidelprops
        To do Auto Bed Leveling you have to have 3 or 4 Z axis lead screws/belts with a separate stepper for each one.
        You config file only specifies one Z axis with one stepper.
        TimsWorkshopundefined 1 Reply Last reply Reply Quote 0
          TimsWorkshop @fcwilt
          @fcwilt That's a bit weird... On my other Ender 5 printer, same setup as this one (but with different offsets/axis) and with that I am able to do a G32
          config.g
          M550 P"Stargate SG-1 - Oneill"                     ; set printer name
          ; Global Variables
          global l_zlead_screw_x		 = 45
          global r_zlead_screw_x		 = 307
          global zlead_screw_y		 = 187.5
          M569 P0 S0                                         ; physical drive 0 goes backwards
          M569 P1 S0                                         ; physical drive 1 goes backwards
          M569 P2 S1                                         ; physical drive 2 goes forwards
          M569 P3 S1                                         ; physical drive 3 goes backwards
          ; Movement
          M92 X80.00 Y80.00 Z800.00 E138.00                  ; set steps per mm
          ; Axis Min/Max
          M208 X5 Y0 Z-20 S1                                 ; set axis minima
          M208 X355 Y355 Z400 S0                             ; set axis maxima
          M950 F0 C"fan1" Q500							   ; Assign Fan0 for Prusa Slicer and default for other slicers
          M106 P0 S0 H-1
          M950 F1 C"nil"									   ; Free up pin F0
          M950 F1 C"fan0" Q500                               ; create fan 0 on pin fan3 and set its frequency
          M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
          M563 P0 D0 H1 F1                                   ; define tool 0
          M575 P1 S1 B57600
          ; Miscellaneous                                          ; load saved parameters from non-volatile memory
          M501
          bed.g
          ; bed.g
          ; Probe points for my 4x bed scews with stock bed springs
          M671 X69:338:69:338 Y51:51:308:308 P0.5			   ; Front-Left:Front-Right:Back-Left:Back-Right
          ; Home and probe near bed screws
          G28 Z; home
          G30 P0 X127 Y58 Z-9999 ; Front-Left
          G30 P1 X380 Y58 Z-9999 ; Front-Right
          G30 P3 X127 Y318 Z-9999; Back-Left
          G30 P2 X380 Y318 Z-9999 S4; Back-Right
          ;G30 P4 X127 Y187.5 Z-9999 ; Left Lead Screw
          ;G30 P5 X380 Y187.5 Z-9999 S6; Right Lead Screw
            Phaedrux Moderator @TimsWorkshop
            @infidelprops said in G32 and This kinematics does not support auto-calibration:
            Can you send M671 by itself to see if it's evaluating your variables correctly?
            Are you trying to do auto leveling or the manual leveling asssitant?
            TimsWorkshopundefined 1 Reply Last reply Reply Quote 1
              TimsWorkshop @Phaedrux
              @phaedrux Thanks mate. I'm trying first the assisted bed levelling so I can adjust the bed knobs, and then I will go and get my G29 and mesh.
              I just sent M671 and it says lead screws are not configured... I've put it in my config.g file towards the bottom of the file, and M671 still reports no leadscrews.
              But what's interesting is I just replaced my variables with the actual values, and M671 now reports leadscrew coordinates configured.
              ;M671 X{global.fl_screw_x}:{global.fr_screw_x}:{global.bl_screw_x}:{global.br_screw_x} Y{global.fl_screw_y}:{global.fr_screw_y}:{global.bl_screw_y}:{global.br_screw_y}
              M671 X30:310:30:310 Y76.8:76.8:338:338
              And now when I run G32, I get readings back to adjust the knobs. Is this a known feature where this Gcode doesn't accept variables?
                dc42 administrators @TimsWorkshop
                @infidelprops you are using the wrong syntax for using variables in a parameter that takes several values. See https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands#Section_Use_of_expressions_within_GCode_commands.
                TimsWorkshopundefined 1 Reply Last reply Reply Quote 2
                  TimsWorkshop @dc42
                  @dc42 ahhh, I did see that but didn't think it applied in this situation. Thanks for pointing that out mate
