    How to diagnose an issue with broken stepper output
    667
      No it doesn't seem like a firmware issue. The phase error would indicate there is a connection issue, but you have tested the motor and wiring successfully on a different driver. That would indicate that the driver has failed/damaged.
      Though if you'd like to update to 3.3 just in case feel free.
      Upload this zip file to the system tab.
      Dima.undefined 1 Reply Last reply Reply Quote 0
      • Dima.undefined
        Dima. @Phaedrux
        @phaedrux Is there a way to check which chip is broken, such that I could try and replace it?
          It's likely the driver chip itself but it's hard to tell without any obvious visible damage to point the way.
          • Dima.undefined
            Dima. @Phaedrux
            @phaedrux ok, thank you for all the help
