    Duet3d 6HC Silicone Heat Bed Config
    • Reaperrhsundefined
      Reaperrhs
      Hi everyone! I apologize, i speak spanish.
      I need help configuring my printer heat bed, i have a 110V 310x310 750w silicone bed installed, I use an SSR with it, the problem is that when I set the temperature my board shot down the bed because it says (Heater 0 fault: temperature rising too slowly: expected 2.27°C/sec measured 0.78°C/sec) but as far I can see temperature rises just fine, what I need to do to change that configuration and give more time before shootdown my heat bed?
      Alex.crundefined 1 Reply Last reply Reply Quote 0
      • Alex.crundefined
        Alex.cr @Reaperrhs
        @reaperrhs
        You need to perform heater tuning. See the link below for additional information.
        https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
        Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
        Reaperrhsundefined 1 Reply Last reply Reply Quote 2
          Reaperrhs @Alex.cr
          @alex-cr thanks, i gonna check that, the problem is that I'm new with macros and the hole RepRap thin, hopefully, I can understand
