    Smoothed fan PWM wiring
    606
    • Diamondbackundefined
      Diamondback
      I've already seen a few posts about using low-pass filters for converting fan PWM outputs to a smooth-ish DC voltage, but I've got a few more specific questions.
      Here's some info on my components:
      • 24V supply
      • 24V / 0.5A / 12W radial blowers (yes, they are big fans)
      • Duet 2 + Duex5
      I want to use 2 of those fans for a static part cooling system in my Toolchanger. Since these are not PWM fans and they work really well when just controlled by voltage (start to turn around 6V@0.1A), I was thinking about smoothing the PWM signal and have a better time driving the fans.
      I was reading in another post by @dc42 that a low-pass filter with an indcutor gives the best results in this scenario and was wondering which specific components I should choose.
      My main concern is the rather large power draw of the fans (almost 30W overall), so I need some help spec'ing the components correctly.
      I plan on connecting the fans in parallel to one of the heater outputs of the Duex, is that alright?
      Can someone help me? 🙂
      cosmowaveundefined dc42undefined 2 Replies Last reply Reply Quote 0
        Diamondback
        Anyone? Maybe @dc42 ?
        • fcwiltundefined
          fcwilt @Diamondback
          @diamondback
          I cannot help you with this sort of thing.
          There was a member who was selling "smoothing" devices. Perhaps you can find his posts.
          • cosmowaveundefined
            cosmowave @Diamondback
            @diamondback @fcwilt it was @zapta
            Mankati FSXT+, DeltaTowerV2, E3D MS/TC
            • oliofundefined
              oliof
              @PCR did build some too
                dc42 administrators @Diamondback
                @diamondback you will need an inductor with inductance of at least 1mH and with both rated current and saturation current at least 1A. Perhaps this one https://www.digikey.co.uk/en/products/detail/bourns-inc/2124-V-RC/775402. Also a 10uF capacitor rated at 35V or more.
                You will need to use either a fan output on the Duet (not the DueX, because you can't select a high PWM frequency on the DueX), or a heater output. If you use a heater output then you will also need an external flyback diode. If you use a fan output then unless your Duet is quite old, it will be included on the Duet.
                Diamondbackundefined 2 Replies Last reply Reply Quote 1
                  Diamondback @dc42
                  @dc42 Thaks a lot David, I ordered the components. Also good tip about the flyback, did not have that on my mind...
                    Diamondback @dc42
                    @dc42 I've wired everything up and it's working very well! Thanks again!
                    One question though, What effect does the PWM frequency have? Is a specific value needed other than "as high as possible"?
                    PCRundefined dc42undefined 3 Replies Last reply Reply Quote 0
                    • PCRundefined
                      PCR @Diamondback
                      @diamondback about 65khz i think
                      • PCRundefined
                        PCR @Diamondback
                        @diamondback
                        65535
                          @diamondback said in Smoothed fan PWM wiring:
                          The smoothing is only effective at high PWM frequencies (you would need a larger inductor for it to work at lower frequencies). The maximum PWM frequency supported is 65535 Hz.
