    can't revive my duet wifi module
    Firmware installation
    392
    • MaracMBundefined
      MaracMB
      i have a spare duet 2 laying around and managed to flash the firmware with bossa.
      Now, i can't for the life of me flash wifi server.
      " Error: M997: File DuetWiFiServer.bin not found "
      sd card is formated in fat32, files are placed,...
      No idea what's wrong.
      m115<CR>
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
      ok
      m122<CR>
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
      Board ID: 08DLM-996AL-K65SJ-6J1F6-3SD6J-KB0QY
      Used output buffers: 1 of 24 (1 max)
      Static ram: 27980
      Dynamic ram: 92268 of which 20 recycled
      Exception stack ram used: 256
      Never used ram: 10548
      Tasks: NETWORK(ready,1884) HEAT(blocked,1476) MAIN(running,2612) IDLE(ready,80)
      Owned mutexes:
      Last reset 00:00:35 ago, cause: reset button or watchdog
      Last software reset details not available
      Error status: 0
      MCU temperature: min 88.5, current 89.5, max 89.6
      Supply voltage: min 1.1, current 1.1, max 1.2, under voltage events: 0, over voltage events: 0, power good: no
      Driver 0: ok, SG min/max not available
      Driver 1: ok, SG min/max not available
      Driver 2: ok, SG min/max not available
      Driver 3: ok, SG min/max not available
      Driver 4: ok, SG min/max not available
      Cache data hit count 48910504
      Slowest loop: 0.22ms; fastest: 0.09ms
      === Storage ===
      Free file entries: 10
      SD card 0 detected, interface speed: 12.0MBytes/sec
      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === MainDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
      === AuxDDARing ===
      Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is ready with "m122" in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 0.14ms; fastest: 0.00ms
      HTTP sessions: 0 of 8
      - WiFi -
      Network state is disabled
      WiFi module is disabled
      Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
      ok
      m572
      Extruder pressure advance: 0.000
      ok
      m552
      ok
      m552 S0
      ok
      WiFi module started
      Error: Failed to initialise WiFi module, code -7
      m997 S1
      ok
        jay_s_uk @MaracMB
        @maracmb it needs to be in the sys folder when running a firmware pre 3.3
        3.3 and up needs to be in a folder called firmware in the root of the sd card
        MaracMBundefined 1 Reply Last reply Reply Quote 0
        • MaracMBundefined
          MaracMB @jay_s_uk
          @jay_s_uk yes. i know. i have that
          alankilianundefined 1 Reply Last reply Reply Quote 0
          • alankilianundefined
            alankilian @MaracMB
            @maracmb
            From THIS page:
            Note: when you run M997 S0, if your board is a Duet WiFi or Ethernet running old firmware, you may get an error message telling you that file DuetWiFiFirmware.bin or DuetEthernetFirmware.bin was not found. If that happens, copy or rename the Duet2CombinedFirmware.bin file to that filename and try again.
            Also, THIS page says you can use a "P" parameter to point to the file you want uploaded.
              @maracmb are you by any chance using M505 in config.g to load system files from somewhere other than /sys ?
              • MaracMBundefined
                MaracMB @dc42
                @dc42 no, there's not even a config loaded on sd card. Should it be?? I just want to flash firmware on wifi module. Can i do it throug bossa or something else?
                Dougal1957undefined 1 Reply Last reply Reply Quote 0
                  Can you send M20 P"/sys/" to see what it's actually reading in the sys folder?
                  • Dougal1957undefined
                    Dougal1957 @MaracMB
                    @maracmb I Think you need at least a basic config just so the FW becomes active to enable you to flash the card via m997.
                    HTH
                    Doug
                    • MaracMBundefined
                      MaracMB @Phaedrux
                      @phaedrux i get nothing 😞
                      M20 P"/sys/"
                      Begin file list
                      NONE
                      End file list
                      ok
                      Got new sd card, formatted with SD card formater, fat32.
                        droftarts administrators @MaracMB
                        @maracmb You don't need a config.g on the card to run M997. Try mounting the SD card first, if you're putting it in after the Duet is turned on. Send M21, then check if you see the sys folder contents with M20 P"/sys/". According to your M122, you are on RRF 3.1.1, so it should be looking in sys for the files.
                        However, I also see in your M122:
                        Interface speed should be 20MBytes/sec. This can indicate a bad SD card, or a failing SD card socket. See https://duet3d.dozuki.com/Wiki/SD_Card#Section_Troubleshooting_SD_Card_issues
